Trigonometry Question from a Math Contest
In summary, the equation sin^8(x) + cos^8(x) = 97/128 can be reduced to a quadratic equation, which when solved, gives the general solution in the reals as \theta = n\pi (+/-) \frac{\pi}{12} or n\pi (+/-) \frac{5\pi}{12} where n is an integer.
MathExpert
sin^8(x) + cos^8(x) = 97 / 128
Mathematics news on Phys.org
The only way I can think off the top of my head is say it is equivalent to:
[tex]128 \left[ \sin^8x + \left(1 - \sin^2x \right)^4 \right] - 97 = 0[/tex]
And really hope it is solvable.
I'd just keep pluggin in trig identities until you reduce things either all to single powers or maybe a quadratic equation of cosines. It shouldn't be too hard, you can use
2cos^2(x) = 1+cos(2x)
2sin^2(x) = 1 - cos(2x)
It would be hard to prove because it's not true.
Edit: Sorry. I assumed you meant it as being true for all x. Do you it is to be solved for x?
It can be reduced to two biquadratic equations,which are solvable.
[tex] 1=[(\sin^{2}x+\cos^{2}x)^{2}]^{2}=(\sin^{4}x+\cos^{4}x+2\sin^{2}x\cos^{2}x)^{2}[/tex]
[tex]=\sin^{8}x+\cos^{8}x+4\sin^{4}x \cos^{4}x+2\sin^{4}x \cos^{4}x+4\sin^{2}x \cos^{2}x (\cos^{4}x+\sin^{4}x) [/tex] (1)
From (1) it follows:
[tex] 1=\sin^{8}x+\cos^{8}x+6\sin^{4}x \cos^{4}x+4\sin^{2}x\cos^{2}x[(\sin^{2}x+\cos^{2}x)^{2}-2\sin^{2}x\cos^{2}x][/tex]
[tex]=\sin^{8}x+\cos^{8}x-2\sin^{4}x \cos^{4}x+4\sin^{2}x\cos^{2}x[/tex] (2)
From (2) it follows:
[tex]\sin^{8}x+\cos^{8}x=1+2\sin^{4}x\cos^{4}x-4\sin^{2}x\cos^{2}x [/tex] (3)
I use:
[tex] \sin 2x=2\sin x\cos x [/tex](4)
to write
[tex]+2\sin^{4}x\cos^{4}x=+\frac{1}{8}(\sin 2x)^{4} [/tex] (5)
[tex]-4\sin^{2}x\cos^{2}x=-(\sin 2x)^{2} [/tex] (6)
Therefore,combining (5),(6) and (3),one gets:
[tex]\sin^{8}x+\cos^{8}x=1+\frac{1}{8}(\sin 2x)^{4}-(\sin 2x)^{2} [/tex] (7)
The initial equation
[tex]\sin^{8}x+\cos^{8}x=\frac{97}{128}[/tex] (8)
,using (7),becomes
[tex] 1+\frac{1}{8}(\sin 2x)^{4}-(\sin 2x)^{2}=\frac{97}{128} [/tex] (9)
,which can be put in the form
[tex] \frac{1}{8}}(\sin 2x)^{4}-(\sin 2x)^{2}+\frac{31}{128}=0 [/tex] (10)
Multiplying (10) by [itex] +8 [/itex] and making the obvious substitution
[tex] (\sin 2x)\rightarrow y [/tex] (11)
,the equation (8) is brought to the canonical form of an biquadratic algebraic eq. in the variable "y":
[tex] y^{4}-8y^{2}+\frac{31}{16}=0 [/tex](12)
We make the substitution:[itex] y^{2}\rightarrow z [/itex] (13)
,and the eq.(12) becomes
[tex] z^{2}-8z+\frac{31}{16}=0 [/tex] (14)
,with the solutions
[tex]z_{1}=4+\frac{\sqrt{225}}{4}=\frac{1}{4}[/tex] (15)
[tex]z_{2}=4-\frac{\sqrt{225}}{4}= \frac{31}{4}[/tex](16)
Comparing (11),(13) and (16),we conclude that [itex] z_{2} [/itex] is not a viable solution.
To be continued.
From (13) and (15),we obtain:
[tex] y^{2}=+\frac{1}{4} [/tex] (17)
,with the solutions:
[tex] y_{1}=-\frac{1}{2} [/tex] (18)
[tex] y_{2}=+\frac{1}{2} [/tex] (19)
It can be easily checked that both solutions (18) and (19) are found in the interval (-1,+1),so they provide viable solutions to the problem.
Putting together (18),(19) and (11),we found two transcendental equations
[tex] \sin 2x=-\frac{1}{2}[/tex] (20)
[tex] \sin 2x=+\frac{1}{2}[/tex] (21)
We solve these eq.in the interval [itex] (-\frac{\pi}{2},+\frac{\pi}{2}) [/itex](for the 'sine' argument,which is 2x).In this case,we can apply the inverse function 'arcsine' to find
[tex] x_{1}=\frac{1}{2}\arcsin(-\frac{1}{2})=-\frac{\pi}{12}[/tex] (22)
[tex] x_{2}=\frac{1}{2}\arcsin(+\frac{1}{2})=+\frac{\pi}{12} [/tex] (23)
Daniel.
EDIT:Thank you,Krab,i wouldn't have seen it,years after...
Looks like it's [itex]\pi/12[/itex]
Let's take [itex]\pi\sim 3.14 [/itex]
[tex] \sin\frac{\pi}{12}\sim 0.25869 [/tex]
[tex] \sin^{8}\frac{\pi}{12}\sim 2\cdot 10^{-5} [/tex](1)
[tex] \cos\frac{\pi}{12}\sim 0.96596 [/tex]
[tex] \cos^{8}\frac{\pi}{12}\sim 75800\cdot 10^{-5} [/tex] (2)
Add (1) and (2) and get:
[tex] \sin^{8}\frac{\pi}{12}+\cos^{8}\frac{\pi}{12}\sim 75802\cdot 10^{-5} \sim\frac{97}{128} [/tex] (3)
Daniel.
Let s = sin^2 x, c = cos^2 x be a solution to the equation.
As Zurtex Started, this equation is a quartic in s:
97/128 = s^4 + (1-s)^4
The symmetry suggests making the substitution s = t + 1/2
Note that t is in the range -1/2 <= t <= 1/2, if we assume to look for real solutions.
97/128 = (1/2 + t)^4 + (1/2 - t)^4
= 2t^4 + 3t^2 + 1/8 = 2t^4 + 3t^2 + 16/128
so
2t^4 + 3t^2 - 81/128 = 0
yielding the solution:
t^2 = -3/4 +/- (1/4) sqrt(9 + 81/16)
= -3/4 +/- (1/4) sqrt(225/16)
= -3/4 +/- (1/4) (15/4)
= -12/16 +/- 15/16
= (-12 +/- 15) / 16
t^2 = -27 / 16 or 3 / 16
However, we know that 0 <= t^2 <= 9/4, so we have the single solution:
t^2 = 3/16
so
t = sqrt(3) / 4
s = t + 1/2 = (2 + sqrt(3)) / 4
Now, s = sin^2 x, so we have:
sin x = (1/2) sqrt(2 + sqrt(3))
Where both square roots could be either positive or negative.
For some reason, I feel that knowing a lot of solutions to the original equation should help me -- if x is a solution, then so is -x, ix, and 90 - x, from which you can make lots more solutions -- but I couldn't get such an approach to help.
dextercioby said:
[tex] \sin^{8}\frac{\pi}{12}+\cos^{8}\frac{\pi}{12}\sim 75802\cdot 10^{-5} \neq 1 [/tex] (3)
But it's not meant to be 1; it's meant to be 97/128, which it is.
BTW, I found your error. In your equation 1, your last 2 should be a 4. Apart from this, the technique is really nice.
Hurkyl,i found two solutions in the reals,in the interval [itex] (-\frac{\pi}{4},+\frac{\pi}{4}) [/itex],because i found it easier to use 'arcsin'.
Solving the eq.
[tex] \sin 2x=\pm \frac{1}{2} [/tex]
on the whole real exis would yield all real solutions to the equation.
If u want to inlcude complex solutions as well,u should use not circular,but hyperbolic trigonometry (identities and stuff).
Daniel.
The solutions have already been given, but perhaps the most "direct" way to do this would be like so :
Let [itex]c = \cos \theta[/itex], [itex]s = \sin \theta[/itex], [itex]S = \sin 2\theta[/itex]
[tex]s^8 + c^8 = 97/128[/tex]
[tex](c^4 + s^4)^2 - 2(c^2s^2)^2 = \frac {97}{128}[/tex]
[tex]((c^2 + s^2)^2 - 2c^2s^2)^2 - 2(\frac{1}{4}S^2)^2 = \frac {97}{128}[/tex]
[tex](1 - \frac{1}{2}S^2)^2 - 2(\frac{1}{4}S^2)^2 = \frac {97}{128}[/tex]
[tex](1 - \frac{1}{2}S^2)^2 - \frac{1}{8}S^4 = \frac {97}{128}[/tex]
Expanding the LHS, rearranging and simplifying,
[tex]\frac{1}{8}S^4 - S^2 + \frac{31}{128} = 0[/tex]
which is a quadratic equation in S^2. Solving that will give the required general solution in the reals :
[tex]\theta = n\pi (+/-) \frac{\pi}{12} [/tex] or [tex]n\pi (+/-) \frac{5\pi}{12}[/tex]
oh boy, anyone in high school taking the amc 12 in a few weeks?
FAQ: Trigonometry Question from a Math Contest
What is Trigonometry?
Trigonometry is a branch of mathematics that studies the relationships between the sides and angles of triangles. It is used to solve problems involving right triangles and can also be applied to other shapes and objects.
How is Trigonometry used in real life?
Trigonometry has many practical applications in fields such as engineering, physics, astronomy, and navigation. It is used to calculate distances, heights, and angles in real-world scenarios.
What are the basic trigonometric functions?
The basic trigonometric functions are sine, cosine, and tangent. These functions represent the ratios between the sides of a right triangle and are used to solve for missing sides or angles.
What is the difference between sine and cosine?
Sine and cosine are both trigonometric functions, but they represent different ratios in a right triangle. Sine represents the ratio of the side opposite an angle to the hypotenuse, while cosine represents the ratio of the adjacent side to the hypotenuse.
How do I use trigonometry to solve problems?
To solve a problem using trigonometry, you will need to identify the given information and the unknown variable. Then, you can use the appropriate trigonometric function and set up an equation to solve for the unknown variable. It is important to remember the relationships between the sides and angles of a right triangle to correctly apply trigonometry.
