- #36
Nugatory
Mentor
- 15,003
- 9,611
Point sources of gravity are tricky because Newton's law of gravity applies in all the space around the point but not at the point itself. One way to see this is that at ##r=0## Newton's law of gravity gives you an infinite force pointing in no direction; the nonsensical result is the math's way of telling you that it doesn't work under those conditions. This is not a problem because such ideal point masses do not exist and it should be no surprise that the math does not describe the behavior of something that cannot exist. However, it does mean that if you try to analyze the behavior of the spaceship at ##r=0## you are committing a logical error similar to the one you are committing if you start a mathematical proof with something like "Let ##n>1## be a common factor of two different prime numbers ##P## and ##Q##..."; the initial premise is bogus so can lead to bogus results.ckirmser said:I mean, theoretically, if we deal with point sources of gravity and acceleration...
There is nothing virtual about that force. When the ship is resting on the track a spring scale between the ship and the track will clearly show that the track is pushing on the ship with some force; we infer that the force of gravity on the ship is equal to and opposite to the force of the track on the ship because the ship is not accelerating so the net force on the ship is zero. If the track were not exerting this upwards force on the ship it would fall towards the center of the earth. Nor is there any "false acceleration" involved; the ##F## in ##F=ma## is always the total force from all sources acting on the object that is accelerating with acceleration ##a##. It pretty much has to be that way because the object in question only has one acceleration vector at any moment, no matter how many different forces are acting on it at that moment.the track is providing a virtual force opposite that of gravity, allowing the ship to get sort of a false acceleration upwards,
