checkmatechamp
- 23
Find the flux of the field F(x) = <x,y,z> across the hemisphere x^2 + y^2 + z^2 = 4 above the plane z = 1, using both the Divergence Theorem and with flux integrals. (The plane is closing the surface)
Obviously, the divergence is 3, so the tricky part is setting up the integral. If it was above the plane z = 0, it would be easy (matter of fact, you could just use the formula V = (2/3)(pi)(r^3) (since it's only half the sphere)), but it's not.
So what I did was say that since z = (rho)*cos(phi), I tried to figure out what the angle phi would be when z = 1. Substituting that in meant that 1 = 2*cos(phi), which means that cos(phi) = 0.5, which means that phi = pi/3
So my integral is as follows:
rho from 0 to 2
phi from 0 to pi/3
θ from 0 to 2pi
∫∫∫σ2sin(φ)dσdφdθ
Integrating with respect to σ gets me sin(φ)*σ3/3, and punching in my limits for σ gets me sin(φ)*(8/3).
Integrating with respect to φ gets me -cos(φ)*(8/3), and then punching in my limits for φ gets me (8/3)*(-cos(pi/3) - (-cos(0)), which is (8/3)(-0.5-(-1)), which is (0.5)(8/3) = 4/3.
Then integrating with respect to θ gets me (4/3)θ, and then substituting my limits gets me (8/3)*pi.
But then if I'm visualizing it correctly, I'm left with an ice cream cone-shaped object. So to get rid of the bottom of the cone, I substitute 1 in for z:
x^2 + y^2 + 1^2 = 4
x^2 + y^2 = 3
r^2 = 3
So r = sqrt(3)
So then I use cylindrical coordinates to subtract out the cone, using the following integral.
z from 0 to 1
r from 0 to sqrt(3)
θ from 0 to 2pi
∫∫∫rdzdrdθ
Integrating with respect to z gets me rz, and punching in my limits gets me r.
Then integrating with respect to r gets me 0.5r^2, and punching in my limits gets me 1.5.
Then integrating with respect to θ gets me 1.5θ from 0 to 2π, which is 3π.
So then (8/3)π - 3π is (-1/3)π. But if everything is above the x-axis, how can it be negative? (If I multiply by 3 to account for the divergence, that's still -π)
Alright, so doing the flux integral, I have the sphere parametrized as <2sinΦcosθ, 2sinΦsinθ, -2sinΦ>. Taking the cross product of the partials gives me <-4sin2φcosθ, -4sin2Φsinθ, 4sinφcosΦ>
The parametrization of the vector field in spherical coordinates is simply <2sinφcosθ, 2sinφsinθ, 2cosφ>. Taking the dot product of the two gives me -8sinφ(sin2φ-cos2φ), which becomes 8sinφcos(2φ)
Then I have to integrate that over the region in the (φ, θ) domain.
φ goes from 0 to π/3, and θ goes from 0 to 2π
So ∫∫(-8sinφ(sin2φ-cos2φ) dφdθ
Using a trig-sub:
∫∫(-8)(-cos(3φ)/6)+((cosφ)/2))
Integrate with respect to φ first.
-8(-sin(3φ)/18) + -8(sin(φ)/2)
(4/9)(sin(3φ)) - 4sinφ
((4/9)(0) - 2*sqrt(3) - 0) - 0
-2sqrt(3) integrate with respect to φ from 0 to 2π
-4π√3
And then you just take the area of the disk on the bottom.
r goes from 0 to sqrt(3), and θ goes from 0 to pπ
∫∫ r dr dθ
0.5r2 from 0 to sqrt(3) is just 1.5
Then basically multiply by 2π gives 3π
So it's 3π - 4π√3
But I'm getting two different answers for solving the flux integral vs. the divergence integral.
