Triple Integral Spherical Coordinates?
In summary, the conversation discusses finding the volume of a 3D shape using triple integrals. The person is confused about which coordinate system to use and how to set up the integral. Eventually, it is determined that using cylindrical coordinates and integrating y over the area of the base will give the desired volume. The conversation also touches on the definition of the triple integral and the difference between finding the volume and evaluating a function over a 3D shape.
Saladsamurai
3,020
I don't think so since it's not a sphere (disk). I have not learned about cylindrical coordinates and Cartesian is just a pain, so I am assuming I am supposed to use polar or something.
Can someone clear up my confusion?
[tex]\int\int\int_E y\,dV[/tex]
where E lies above the plane z=0, under the plane z=y and inside the cylinder [itex]x^2+y^2=4[/itex]
How would you proceed here if you DON'T want to use Cartesian Coordinates?
Casey
Duuuudddddeeeeeeee... I don't get it... I see a cirlcle (the domain of E) and I automatically think polar... but it is 3-D so tha doesn't male sense right? For 3-D you need spherical coordinates, but that doesn't make sense either.
I am thinking I am not supposed to use Cartesians, cause that integrals a pita. But maybe I am wrong; however we usually don't get integrals that require the use of tables (for now).
To find the volume you integrate the height y, over the area in the x-y plane. Use polar coordinates in the x-y plane. That's really cylindrical coordinates, but you don't have to call it that.
Hey Dick! I don't have to much experience with this. Do I set up the integral like this:
[tex]\int\int_D\int_0^y y\,dz\,dA[/tex]
where D is the region bounded by x=0 and x^2+y^2=4
thus the integral becomes
[tex] \int_{\theta=\frac{-\pi}{2}}^{\frac{\pi}{2}}\int_{r=0}^2\,y^2\,dr\,d\theta[/tex]
and then just plug in what y is in polar coordinates? Or did I F this one up royally?
Thanks :smile:
Not that royally, but it could use some work. Why y^2? If you are integrating y over the area in the x-y plane it's only a double integral over r and theta. And doesn't theta go from 0 to pi? And isn't the area measure in polar coordinates r*dr*dtheta?
I am missing something... where did the third integral go then? The y^2 came from integrating y*dz wtr z--->y*z from z=0 to z=y.
Then I though you integrate that over the x-y area?
If you are setting this up as a triple integral, you integrate 1 over the coordinate limits to get the volume. The integral of 1*dz from z=0 to z=y is y.
Maybe I should start over here. If I take the Volume and project it onto the x-y plane, I get D, which takes the form of a semi-circle that follows a path from theta=0 to pi at a radial distance 2 from the origin.
Now I want to integrate the function y wrt r and theta? Is that what you are saying?
Yes, that's exactly what I'm saying. You integrate the height of the region over the area of the base.
Why am I integrating 1 ? I am looking for its 4-D volume (or whatever it is called) aren't I.
[tex]\int\int\int y\,dz\,dr\,d\theta[/tex]
Once more. Is this my integral? I am just confused, now.
I think it's time for bed! Thanks for the help Dick :smile: I will look at it in the a.m. I am getting too flustered right now. I understand every other triple integral assigned to us except this one. Moreover, I can solve this one in Cartesian Coordinates just fine, so long as I have an integral table handy. So I have no idea why this does not make sense to me in Cylindricals.
In Cartesian I have
[tex]\int_x\int_y\int_z\,y\,dz\,dy\,dx[/tex] ... Not sure what the big deal is now.
I'm going to pretend you didn't say that. A volume integral is the integral of 1 over the 3d coordinate limits. Look it up.
What is the definition of the [tex]\int\int\int_E f(x,y,z)\,dV[/tex]
It is not the volume of E
correct? If I wanted the volume of E I would integrate the function
[tex]\int\int\int_E \,dV[/tex]
Correct?
But my problem does not ask me to find the volume of E. It asks me to evaluate
where f(x,y,z) is simply y. Is that not the case here? I am NOT looking for volume (in the three dimensional case)?
Correct?
Yes. Completely, utterly, right. I somehow thought you were looking for the volume and you're not. Sorry, sorry. Yes, the y^2 is correct. But shouldn't it be y^2/2?
I don't think so: if I have [tex]\int\int_D\int_0^y y\,dz\,dA[/tex]
Just taking care of that innermost integral with respect to z I have
[tex]\int_0^yy\,dz=y\int_0^y\,dz=y*z|_0^y=y^2[/tex]
yes?
Yep, you win again. For a fixed x,y y is a constant. You might be better at this than I am.
Yessss! I win! Just kidding.:biggrin: Okay so back to bed. I think I'll be able to sleep now :smile:
So back to my proposal:
Now I have integrated the function with respect to height and got y^2. Now I evaluate a double integral over D of y^2 (but in polar terms=(r*sintheta)^2). Something to the affect of:
[tex]\int\int_D\,y^2\,dA=\int_0^\pi \int_0^2\, r^2*sin^2\theta\,* r\,dr\,d\theta[/tex]
That looks fine to me.
Related to Triple Integral Spherical Coordinates?
What is a triple integral in spherical coordinates?
A triple integral in spherical coordinates is a mathematical tool used to calculate the volume of a three-dimensional object in a spherical coordinate system. It involves integrating over three variables: radius, azimuthal angle, and polar angle.
How do you convert a triple integral from Cartesian coordinates to spherical coordinates?
To convert a triple integral from Cartesian coordinates to spherical coordinates, you can use the following equations:
x = r sinθ cosφ
y = r sinθ sinφ
z = r cosθ
where r is the radius, θ is the polar angle, and φ is the azimuthal angle.
What is the region of integration in a triple integral in spherical coordinates?
The region of integration in a triple integral in spherical coordinates is a three-dimensional region defined by the limits of the three variables: r, θ, and φ. These limits determine the boundaries of the volume being integrated.
What are the advantages of using spherical coordinates for triple integrals?
There are several advantages of using spherical coordinates for triple integrals, including the ability to easily integrate over spherical objects, simplification of the region of integration, and the ability to solve certain types of problems more efficiently. Additionally, some physical systems are naturally described in spherical coordinates, making it useful for scientific applications.
What are some common applications of triple integrals in spherical coordinates?
Triple integrals in spherical coordinates are commonly used in physics, engineering, and other scientific fields to calculate physical quantities such as mass, electric charge, and moment of inertia. They are also useful for solving problems involving spherical objects, such as planets and stars, and for analyzing physical systems with spherical symmetry.
