Triple integration to find volume of regions
In summary, the person is trying to solve a problem using spherical coordinates, but is getting incorrect results. They then realize that they may be doing something wrong and try to find a different solution.
DryRun
http://s2.ipicture.ru/uploads/20111231/kczcXUuF.jpg
The attempt at a solution
So, I'm using the transformation to spherical coordinates (ρ,∅,θ)
Description of region:
For θ and ∅ fixed, ρ varies from 0 to 4.
For θ fixed, ∅ varies from 0 to ∏. (i suspect the error is here)
θ varies from 0 to 2∏.
But i don't know what I'm doing wrong. I've checked my limits, but i think that's the problem, since i can't get the correct answer.
When i calculate ∅ by expanding into (ρrsin∅cosθ)^2 + (ρrsin∅sinθ)^2 = 4
Substituting r=2, i get the value of ∅ = ∏/6, which i also tested as the limits from 0 to ∏/6 and still got the wrong answer.
I then tested limits ∏/6 to 5∏/6 and still wrong.
Here is the answer from my notes:
http://s2.ipicture.ru/uploads/20111231/B1yTY1Ye.jpg
I don't know about you but I get an error when I try to see the attachments.
Try to refresh the page. They load perfectly fine for me. I'm using Firefox browser.
Here is a mirror of the question (click on the image to enlarge):
And the answer:
Find the volume of the regions described by inside both
o x2+y2+z2 = 16
o x2+y2 = 4Answer: [itex]\frac{32π(8-33/2)}{3}[/itex]
I've already drawn the graph but i don't know which limits are wrong and why.
OK, so here are my calculations:
From
[tex]x^2+y^2+z^2 = 16[/tex]
I know, by formula, that
[tex]\rho^2= 16[/tex]
So,
[tex]\rho=4[/tex]
For θ and ∅, i think it's obvious, at least i think so. I don't know where i went wrong.
o x2+y2+z2 = 16
Are you suggesting that i find the volume of the sphere first and then subtract the volume of the cylinder from that? I can find the volume of the sphere but not sure how to find the volume of cylinder using spherical coordinates.
If you did so, I mean finding the volume of the cylinder alone, you would miss the two little spherical part over the bases of the cylinder. Anyway, I want to try it on my own, I'll tell then. :D
It looks like it's going to be a long night...
I tried something but I did some error, it was my last try for today.
Anyway, my limits where [0,2π] for θ, [π/6,5π/6] for ø and [1/(2sinø), 4] for p. In fact the minimum of the radius changes with ø and in particular I found that function for p. My result is terrible, I get a negative number, but I don't have time now, I'll try again tomorrow maybe. Anyway, that's the right idea. Good Year!
Hello sharks !
The problem can be done more easily in cylindrical coordinates. If you use spherical coordinates, it looks to me as if you will have to break this up into the sum of two integrals.
For the part of the region bounded by the sphere, 0 ≤ ρ ≤ 4. In this region, 0 ≤ ɸπ/6 , also, 5π/6 ≤ ɸπ.
For the part of the region bounded by the cylinder, π/6 ≤ ɸ ≤ 5π/6, and ρ does not go to 4.
In this region [itex]x^2+y^2=\rho^2-\rho^2\cos^2(\phi)=4\,.[/itex] Use that to figure out the bounds for ρ.​
Interesting though the triple integration might be, and tempting as it might be to change coordinates, I would just calculate where the sphere meets the cylinder and integrate the area over z to find the volume of the cap.
[tex]\int^{4}_{√12}\pi(16-z^{2})dz[/tex]
Sorry, posted wrong advice. Lol. This thing needs to be done in cylindrical coordinates I believe. Or as Joffan suggested, in standard Cartesian coordinates.
Is that the ripple effect of the New Year? So many wrong advices in this thread. LOL
But seriously, this question is found at the end of the triple integral using spherical coordinates section, and it must be solved using transformation to spherical coordinates.
I guess the main question here is - is it possible to solve the volume of a cylinder using cylindrical coordinates? I think yes.
SammyS, i am following your idea, which is: sum of the top and bottom cones with spherical hats and concave middle cylindrical shape.
Is that a mistake? It's supposed to be [itex]x^2+y^2=\rho^2\sin^2(\phi)=4\,,[/itex] so [itex]\rho\sin(\phi)=2\,.[/itex]
It's the same thing, just a different way to arrive at it.
[itex]\rho^2-\rho^2\cos^2(\phi)=\rho^2(1-\cos^2(\phi))[/itex]
[itex]=\rho^2\sin^2(\phi)[/itex]​
... but the form you have it in will definitely work better.
I'm drunk, aren't you. For the love of god.
OK, if i understood correctly, i should be able to derive the final answer as the sum of these 3 triple integrals:
The top cone:
[tex]\int^{2\pi}_{0}\int^{\frac{\pi}{6}}_{0} \int^{4}_{0}\rho^2sin\phi\,.d\rho d\phi dz[/tex]
The bottom cone:
[tex]\int^{2\pi}_{0}\int^{\pi}_{\frac{5\pi}{6}} \int^{4}_{0}\rho^2sin\phi\,.d\rho d\phi dz[/tex]
The middle section, lined by the sides of the cylinder:
[tex]\int^{2\pi}_{0}\int^{\frac{5\pi}{6}}_{\frac{\pi}{6}} \int^{\frac{2}{\sin\phi}}_{0}\rho^2sin\phi\,.d\rho d\phi dz[/tex]
I added the 3 answers from the 3 integrals above and it's wrong.
LOL. I've been most of the night. It just took a little longer to kick in and disable my typing skills. :biggrin:
The top cone:
Note that the volume of the top cone equals the volume of the bottom cone.
What did you get for an answer ?
The top cone:
The bottom cone:
I did it in the same way before reading this post and I got the same answer, I mean the correct one posted.
You may deal with it also by calculating the volume of the outer region of the sphere, I mean that out of the cylinder and inside the sphere, and then subtract the result to the volume of the whole sphere. This way the boundary of p is [2/sinø, 4] and that of ø is [π/6, 5π/6]. I haven't checked this way yet, but it must be right.
Yes, i got the same answer for both cones:
[tex]2\pi(\frac{64}{3}-\frac{32\sqrt3}{3})[/tex]
I found it easier to convert it to a numerical answer (in order to add and find the total volume): 17.95812724
The volume of the middle concave cylinder section:
[tex]16\sqrt3 = 174.124739[/tex] (maybe this is the wrong part?)
So, the total volume = (2 x 17.95812724) + 174.124739 = 210.0409934
However, the correct numerical answer is: 93.95783414
EDIT: OK, i got it. I made a mistake when integrating the middle cylinder section. The answer is 58.04157697
The total volume gives me 93.95783414, which is correct!
Thanks to SammyS and others for your advice.
Related to Triple integration to find volume of regions
1. What is triple integration and why is it used to find volume of regions?
Triple integration is a mathematical technique used to find the volume of 3D regions in space. It involves integrating a function over three variables, typically x, y, and z, to determine the total volume of the region. It is used because it allows for the calculation of complex and irregularly shaped volumes that cannot be easily found using other methods.
2. How do you set up the triple integral for finding volume of a region?
To set up a triple integral for finding volume, you must first determine the limits of integration for each variable. This involves understanding the boundaries of the region in each direction. Once the limits are determined, the integral is set up as the triple integral of the function over the specified limits.
3. Can triple integration be used to find the volume of any 3D region?
Yes, triple integration can be used to find the volume of any 3D region. However, the process may be more complicated for irregularly shaped regions and may require breaking the region into smaller, simpler shapes to integrate over.
4. What are some real-world applications of triple integration for finding volume?
Triple integration is used in various fields of science and engineering, such as physics, chemistry, and civil engineering, to calculate volumes of complex shapes. It is also commonly used in computer graphics for 3D modeling and animation.
5. Are there any limitations to using triple integration for finding volume?
One limitation of using triple integration is that it can be a time-consuming and complex process, especially for irregularly shaped regions. Additionally, it may not be suitable for regions with changing densities or materials, as it assumes a constant density throughout the entire region.
