TRIPOLI-4 version 9S How to installing on Unix system for Ubuntu22.04
  • Thread starter emilmammadzada
  • Tags
    System Unix
In summary, TRIPOLI-4 version 9S is a Monte Carlo simulation software used for modeling and simulating radiation transport in various materials and geometries. To install it on a Unix system, you will need to download the installation package from the official website and follow the instructions in the user manual. It is compatible with Ubuntu 22.04 and has specific system requirements, including a Unix-based operating system, 2 GB of RAM, and 5 GB of free disk space. However, it also requires a Fortran compiler and a C++ compiler. There is a cost associated with installing TRIPOLI-4 version 9S on Unix, as it is not free and requires a license to use. Pricing information
emilmammadzada
122
TL;DR Summary
TRIPOLI-4 version 9S How to installing on Unix Ubuntu22.04
TRIPOLI-4 version 9S How can I find the user manual for installing and running this nuclear code?
The user manual for the TRIOPLI-4 version 9S nuclear code can be found on the website of the Lawrence Livermore National Laboratory. Navigate to the Nuclear Technology page and then select "Reactor Analysis" from the dropdown menu. Scroll down until you see a link to the TRIOPLI-4 version 9S User's Guide.
Likes emilmammadzada
FAQ: TRIPOLI-4 version 9S How to installing on Unix system for Ubuntu22.04
How do I download TRIPOLI-4 version 9S for installation on Ubuntu 22.04?
To download TRIPOLI-4 version 9S, you need to visit the official website of the software. Typically, you will find a download link for the Unix version. Make sure you have the appropriate permissions to download and install software on your system.
What are the prerequisites for installing TRIPOLI-4 version 9S on Ubuntu 22.04?
Before installing TRIPOLI-4 version 9S, ensure that your system has the necessary dependencies. These usually include a compatible C++ compiler (like GCC), CMake, MPI (Message Passing Interface), and other libraries such as HDF5 and Python. You can install these dependencies using the apt package manager.
How do I install the required dependencies for TRIPOLI-4 version 9S on Ubuntu 22.04?
Open a terminal and run the following commands to install the required dependencies:
sudo apt updatesudo apt install build-essential cmake libhdf5-dev libopenmpi-dev python3
This will ensure that all necessary tools and libraries are available for the installation.
What are the steps to compile and install TRIPOLI-4 version 9S on Ubuntu 22.04?
After downloading the source code, extract the files and navigate to the directory. Then run the following commands:
mkdir buildcd buildcmake ..makesudo make install
These commands will configure, compile, and install TRIPOLI-4 on your system.
How can I verify that TRIPOLI-4 version 9S has been installed correctly on Ubuntu 22.04?
To verify the installation, you can run a test simulation provided with the software or check the version by running the following command in the terminal:
tripoli4 --version
If the installation was successful, you should see the version information of TRIPOLI-4 displayed.
