- #36
Big-Daddy
- 343
- 1
epenguin said:I have talked about [H+] in e.g. #4,18
I thought rather than repeating I would let you calculate it and draw you own conclusions.
The original phosphoric acid solution was 0.2M. It is not all that drastically diluted by the titration.
And you are worrying about the effect of something present at about 10-8M ?
Edit: or more exactly at nearly 10-6M, since that is [OH-].
OK sorry I haven't been available over the last few days to talk this over, I was busy. Let me start from the beginning.
If we neglect [H3PO4] and [PO43-], as the relevant pKa values are not within 3 units either way of the pH (7.8), we can write:
(Notation is that n[Species] is number of moles of that species. Working with this enables us not to worry about V when it comes to the conjugate base forms of the acid, as this V is not known since we don't know how much titrant was added.)
Mass balance for P: n[Ptot]=n[H2PO4-] + n[HPO42-]
Ratio of Conjugate Bases: n[HPO42-]/n[H2PO4-]=Ka2/[H+]
Charge Balance: n[K+]+n[H+]=n[H2PO4-]+n[HPO42-]+n[OH-]
Now is the difficult bit and whatever I read of the post you just suggested (#18) I do not see how we can solve this. We do not know n[H+] or n[OH-] so how can we work out n[K+]? Kw is useless because Kw=[H+]*[OH-], not Kw=n[H+]*n[OH-].
I'm not sure I understand your argument when it comes to dilution not having much effect. The moles of total acid are not going to change with dilution; meanwhile, given that we may have added nearly as much volume of KOH as we started with acid, I think it's ridiculous to say the volume hasn't changed at all.
Are you suggesting the approximation we make is n[H+]=0, n[OH-]=0? Despite reading your last post again to myself I cannot see how this is justified except by calculating the values, and we cannot do that yet (if we could then there'd be no need to set them =0). If we could calculate n[H+] that would solve the problem on its own (as we just divide this by [H+] to find V, and the value of [H+] is known to be 10^(-7.8)).
Maybe if, instead of trying to tackle the various problems that are cropping up for me (as we clearly think in slightly different ways regarding this problem), you simply lay out your general technique for solving the problem (from the stage I reached of the equations I wrote above for mass balance, charge balance, etc.), with every step listed, I will understand where the solution to my own problems lies.
