Trouble explaining Gauge Symmetry
In summary, Gauge Symmetry is a principle in physics that states that a system with potentials at every point and time behaves the same as a system with the same potentials, but with a constant added.
Whovian
652
I'm currently attempting to explain the concept of Gauge Symmetry to a friend. Copied and pasted pretty much directly from MathIM,
Basically, a system with voltage V(P,t) at every point P and time t behaves exactly like the same system, but with voltage V(P,t)+C, where C is a constant wrt position and time.
(And the same applies for any other potential field, such as gravitational potential.)
Would this be correct? I've tried explaining Gauge Symmetry multiple times to no avail (don't worry, it's not a technicality barrier, I think they're familiar with elementary electrodynamics,) so does anyone have a suggestion of an easier way to explain this?
Electrostatic and gravitational potential are the easiest systems, I think.
"Change the potential by the same amount everywhere, and physics stays the same".
These potentials that we use in physics are just devices of our mathematical models used to describe the universe, and they aren't "real". Sometimes our mathematical models have more degrees of freedom than exist in nature, and there is some redundancy in the choice of numbers. If you picture a physics model as a relation whose domain is the values in a model and whose range is possible realities, then we would have multiple values mapping to the same reality.
From a more mathematical viewpoint, you could view sets of values pertaining to the same reality as an equivalence class. Then, the "correct" theory (from an Ockham's razor stance) would take parameters from the quotient set of all parameters modulo the gauge symmetry. The gauge symmetry is just meaningless excess.
Nevertheless, sometimes it's easier to work with mathematical structures with extra redundancy because the rules for those math structures have already been worked out. For example, we might use a 2x2 matrix to represent something with 3 degrees of freedom when a 2x2 matrix has 4 degrees of freedom because physicists don't (always) want to invent a whole new math structure for the 3 degree of freedom object when 2x2 matrix works.
Hello,
Thank you for reaching out for help in explaining Gauge Symmetry to your friend. It can be a complex concept to grasp, so I understand your struggle.
To put it simply, Gauge Symmetry is a mathematical concept that describes the relationship between a physical system and the way it is measured. In the example you provided, the voltage at a particular point and time can be described as V(P,t). This is the "gauge" or measurement of the system. However, this measurement can also be described as V(P,t)+C, where C is a constant. This means that the system behaves in the same way regardless of the value of C, as long as it is a constant.
In other words, the physical system itself does not change, but the way we measure it can vary. This is similar to how we can use different units to measure the same quantity, such as using inches or centimeters to measure length. The physical object remains the same, but the units of measurement can change.
Gauge Symmetry is an important concept in physics because it helps us understand the relationship between physical systems and the way we measure them. I hope this explanation helps your friend better understand Gauge Symmetry. Let me know if you have any further questions.
Best,
Related to Trouble explaining Gauge Symmetry
1. What is gauge symmetry?
Gauge symmetry is a fundamental concept in physics that describes the invariance of a physical theory under certain transformations. In simpler terms, it means that the laws of physics do not change when certain quantities (called gauge fields) are altered. These gauge fields can represent things like electric and magnetic fields, and their transformations are known as gauge transformations.
2. Why is gauge symmetry important?
Gauge symmetry is important because it allows us to accurately describe and predict the behavior of physical systems. It is a fundamental principle in many areas of physics, including electromagnetism, quantum mechanics, and the Standard Model of particle physics. Without gauge symmetry, we would not have a consistent and reliable way of understanding the physical world.
3. How is gauge symmetry related to symmetry breaking?
Gauge symmetry and symmetry breaking are closely related concepts. In gauge theories, symmetry breaking occurs when the gauge symmetry is broken, meaning that the laws of physics are no longer invariant under certain transformations. This can happen through interactions with other fields or particles, and it leads to the emergence of new properties and behaviors in the system.
4. Can you give an example of gauge symmetry in action?
One example of gauge symmetry in action is in the theory of electromagnetism. The electromagnetic force is described by a gauge theory, and the gauge symmetry in this case is known as U(1) symmetry. This symmetry allows us to accurately describe the behavior of electromagnetic fields and particles, such as photons, in a consistent and reliable way.
5. What are the practical applications of understanding gauge symmetry?
Understanding gauge symmetry has many practical applications in physics. It allows us to accurately describe and predict the behavior of physical systems, which is crucial in fields such as particle physics and quantum mechanics. Additionally, gauge theories have been used to develop technologies such as lasers, which rely on understanding the behavior of electromagnetic fields and particles at a fundamental level.
