MHB Trouble proving multiplication cancellation law fails
  • Thread starter Thread starter skate_nerd
    Law Multiplication
The discussion revolves around the failure of the multiplication cancellation law in the context of \(\mathbb{Z}_6\). A participant initially believes they have proven the law holds but is corrected by others who point out flaws in their reasoning, particularly regarding the implications of integer relationships. They are advised to explore the absence of zero divisors and to consider counterexamples, which ultimately leads to the discovery that the law fails under specific conditions, such as when \( [j]=[0] \), \( [k]=[2] \), and \( [m]=[3] \). The conversation emphasizes the importance of correctly interpreting integer relationships in mathematical proofs. Understanding these concepts is crucial for grasping the multiplication cancellation law's validity.
skate_nerd
The problem given says to consider the addition and multiplication \(\oplus\) and \(\odot\) on \(\mathbb{Z}_6\) defined by
$$[m]\oplus[n]=[m+n]$$ and $$[m]\odot[n]=[mn].$$I need to verify, among other things, that the multiplication cancellation law fails (if \([m]\odot[j]=[m]\odot[k]\) and \([m]\neq{0}\), then \([j]=[k]\) ).
With a bit of inspection, I began to believe that it in fact does not fail, and I thought I constructed a valid proof showing why, until my professor told me otherwise.
Suppose that \([m]\odot[j]=[m]\odot[k]\). This can be written as \([mk]=[mj]\). This holds if \([mj]=[mk+6p]\) for any integer \(p\).
So we have that
$$mj=mk+6p$$ $$6p=mj-mk$$ $$6p=m(j-k)$$ $$6\frac{p}{m}=j-k$$ \(j=k+6\frac{p}{m}\) where \(\frac{p}{m}\) is an integer. This is the same thing as writing \([j]=[k]\), because \([j]=[k+6\frac{p}{m}]\).
I am pretty sure that this proves the multiplication cancellation law holds but apparently that isn't the case, making me feel like I really don't understand this topic well...
If anybody could help show me where my logic goes south, that would be great. Thanks guys
Re: trouble proving multiplication cancellation law fails
The fact that $j-k$ is an integer does not imply that $p/m$ is, although it does imply that $6p/m$ is an integer.
To grasp what's going on, go through the proof that cancellation law holds when there are no zero divisors. See where the absence of zero divisors is used. Then find zero divisors in $\mathbb{Z}_5$ and construct a counterexample to your statement. Go through your proof and see exactly which step is wrong.
[2]*[3] = [0]
[0]*[3] = [0]
[2] does not equal [0].
A couple things:
Did you mean to say find zero divisors in $\mathbb{Z}_5$? Because the problem is considering $\mathbb{Z}_6$.
Also, you say that $j-k$ being an integer DOES imply that $6\frac{p}{m}$ is also an integer. So if this is true, then my conclusion would still prove the multiplication cancellation law does not fail, right? I concluded that $[j]=[k+6\frac{p}{m}]$, meaning \(j\) equals \(k\) plus some integer.
Would this not be sufficient proof because $6\frac{p}{m}$ has some values where it would not make $[j]=[k]$?
By the way, I found a counter-example that does prove that the law fails. It fails when $[j]=[0]$, $[k]=[2]$, and $[m]=[3]$. I am just still a bit perplexed as to why the proof I constructed initially is invalid.
In $\mathbb{Z}_6$.
To conclude that $[j]=[k]$, you need to show that $j=k+6q$ where $q$ is an integer, not that $j=k+q$ where $q$ is an integer. You showed that $j=k+6p/m$, but $p/m$ is not necessarily an integer.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
