Trouble understanding Continuity
  • Thread starter crispy_nine
  • Tags
    Continuity
In summary, the conversation is discussing a problem involving showing the continuity of a function f at the point (0,0). The function is defined as ysin(1/x) if (x,y) does not equal (0,0), and 0 if (x,y) = (0,0). The solution involves understanding the definition of continuity and using the epsilon-delta definition of limit to show that the function is continuous at (0,0).
crispy_nine
Hey folks,
I have this one problem that seems unclear to me:
Show that the function f is continuous at (0,0) for
f(x,y) = ysin(1/x) if (x,y) do not equal (0,0)...and 0 if (x,y) = (0,0)
I'm thinking though, as with single variable calc, f is continuous at (a,b) provided that f(a,b) exists right? Therefore the top function is not continuous at (0,0), correct? But then again it states that x and y never do equal (0,0). I think I don't understand the question. Could somebody rephrase it or give me a hint? Cheers
I think it would be good for you to start with the equivalent 1 dimensional problem, which is:
Let f(x) = x sin(1/x) for all x not equal to zero, and define f(0) = 0. Show that f is continuous everywhere.
crispy_nine said:
Hey folks,
No, even in single variables that is not right. f is continuous at (a,b) provided that (1) f(a,b) exists, (2) [itex]lim_{(x,y)\rightarrow (a,b)}[/itex] exists, and (3)[itex]lim_{(x,y)\rightarrow (a,b)}= f(a,b)[/itex].
Even from your mistaken statement that does not follow. f(0,0) certainly does exist. You are told that "f(x,y)= 0 if (x,y)= (0,0)". In other words that f(0,0)= 0.
Your reference to "the top function" implies that you think there are two functions here. That is incorrect. There is only one function.
No, it does NOT say "x and y never do equal (0,0)". It says that if x and y are not (0,0) then f(x,y) has a certain formula.
Suppose a function f(x) were defined by "f(x)= 2x- 3 if x is not 1, 2 if x is 1", what is f(1.001)? What is f(1)? Is that function continuous at x= 1?
Thanks for the helpful insight so far.
It is now clear to me that f(0,0) exists and is zero, so basically all I have to do to show that the function is continuous is prove that the limit of ysin(1/x) exists and is zero as (x,y) goes to (0,0).
Now, how is that possible if the limit of (1/x) does not exist as x goes to zero? Is l'Hopitals rule somehow applicable in this situation?
No one has said that lim(1/x) exists as x goes to 0!
What is being said is that (in your problem lim ysin(1/x) exists as x and y both go to 0 (independently) and (Crosson's one dimension example) x sin(1/x) exists as x goes to 0. What happens of x sin(1/x) for x very small? How large is "x"? How large is sin(1/x)? How large is their product?
Use the epsilon-delta definition of limit and the fact that |sin(z)| <= 1 for all z. It will be clear that delta=epsilon does the trick.
FAQ: Trouble understanding Continuity
What is continuity?
Continuity is a mathematical concept that describes the smooth and unbroken nature of a function. It means that as the input of a function approaches a certain value, the output of the function also approaches that same value.
Why is continuity important?
Continuity is important because it allows us to make predictions and draw conclusions about the behavior of a function. It also helps us to understand the relationship between different values of a function and how they change.
What are the types of discontinuities?
There are three types of discontinuities in a function: removable, jump, and infinite. A removable discontinuity occurs when there is a hole or gap in the graph of a function. A jump discontinuity occurs when there is a sudden jump or break in the graph. An infinite discontinuity occurs when the function approaches positive or negative infinity.
How do you determine if a function is continuous at a point?
To determine if a function is continuous at a point, you need to check three conditions: 1) the function is defined at the point, 2) the limit of the function exists at the point, and 3) the limit and the value of the function at the point are equal.
What are the methods for finding continuity?
There are several methods for finding continuity in a function. One method is to use the limit definition of continuity to check if the function satisfies the three conditions mentioned above. Another method is to use the intermediate value theorem, which states that if a function is continuous on a closed interval, then it takes on every value between the minimum and maximum values on that interval. Finally, you can also use graphical analysis to determine if a function is continuous.
