Trouble with FBD: Is There an Upward Force?
  • Thread starter Physicsstudent2
  • Tags
    Fbd Force
In summary, the conversation discusses the concept of finding the normal force on objects in an elevator that is accelerating upwards. The main forces at play are the force of gravity, friction, and the applied force, but the effect of the upwards acceleration also needs to be considered. The conversation also touches on the sensation of weight in an accelerating elevator and how it differs from the feeling on Earth. Overall, the key takeaway is that the normal force is the upward force acting on the blocks and can be found by analyzing the vertical forces using Newton's 2nd law.
Physicsstudent2
Two blocks (m1 = 15 kg and m2 = 25 kg) are placed side by side on an elevator
accelerating at 2.2 m/s2
[up]. The coefficients of friction between the blocks and the
floor are µs = 0.8 and µk = 0.6. If a horizontal force of 400 N is applied to the first block, find the acceleration of the system.
F = ma
Fg = mg
I am having trouble coming up with a FBD. I know there is a Fg, Fn, friction, and applied force on the masses, but would there be another force going upwards because of the acceleration?
What is the effect of the upwards acceleration? In a nutshell?
won't the upwards force have to be greater than the force of gravity so that the elevator can accelerate upwards
Okay, but that doesn't help you much. Put it another way: what does it feel like in the elevator? Does it still feel like planet Earth?
no it doesnt. depending on which direction you are moving you will feel you're a different weight
So, can we just take the "effective" gravity to be greater than the usual ##g##, but otherwise proceed as normal?
The upward force acting on the blocks is the normal force Fn. To find the normal force on each block, analyze the vertical forces (apply Newton's 2nd law).
Likes nasu
FAQ: Trouble with FBD: Is There an Upward Force?
What is FBD and why is it important in science?
FBD stands for Free Body Diagram, which is a visual representation of all the forces acting on an object. It is important in science because it helps us understand the motion and behavior of objects and allows us to accurately predict their movements.
What is an upward force and how does it affect an object?
An upward force is a type of force that acts in the opposite direction of gravity, pushing an object towards the sky. It can affect an object by counteracting the force of gravity and causing it to rise or remain in a state of equilibrium.
How can I determine if there is an upward force present in a FBD?
To determine if there is an upward force present in a FBD, you can look for any arrows pointing upwards in the diagram. These arrows represent the magnitude and direction of the upward force acting on the object.
What are some examples of objects that experience an upward force?
Some examples of objects that experience an upward force include a balloon being filled with air, a bird flying in the sky, and a rocket launching into space. In all of these cases, the upward force is counteracting the force of gravity and causing the object to move upwards.
Can an object experience multiple upward forces at the same time?
Yes, an object can experience multiple upward forces at the same time. For example, a book sitting on a table experiences an upward force from the table supporting it, as well as an upward force from the air molecules pushing up on it. These forces combine to keep the book in a state of equilibrium.
