Trouble with Proof of Optimal Launch Angle
In summary, the maximum range of a skier going down a ski jump can be calculated using the equations provided, where phi represents the angle of the hill with respect to the horizontal. By treating the skier's path as a parabola and a line, the maximum range can be found by solving for the values of m, k, and l. The horizontal and vertical distances to the top of the jump are necessary to find k and l, which can then be substituted into the equations to calculate the maximum range.
stoffer
Here is my problem, can anyone help me out?
Prove the maximum range of a skier going down a ski jump is given by
(theta) = 45degrees - phi/2 , where theta = optimal launch angle , phi = slope angle of take off with respect to the incline of the hill.
I have the following equations to use
Xf = Vi*cos(theta)*t = d*cos(phi)
Yf = Vi*sin(theta)*t - (1/2)g*t^2 = -d*sin(phi)
Where, Xf= final x component, Yf= final y component, Vi = velocity at launch, t= time jumper is in air, g= grav. constant, d = distance traveled along the inlcine of the hill
I am trying to eliminate t in the above equations and then differentiate to maximize d in terms of theta.
Any ideas how to do this? What is a good first step? Any help you can give will be greatly appreciated.
Thanx
minor correction
phi = angle the hill makes with the horizontal
WARNING: This post contains technical errors, but it should still be instructive.
If you treat this as a system of a parabola and a line, you get the equations:
The slope:
[tex]y=mx[/tex]
and
the skiers' path:
[tex]y=-(x-k)^2+l=-x^2+2kx-k^2+l[/tex]
Substitution yields
[tex]y=-m^2y^2+2kmy-k^2+l[/tex]
so
[tex]y=\frac{2km+\sqrt{4k^2m^2+4m^2(l-k^2)}}{2m^2}[/tex].
Which can obviously be simplified to:
[tex]y=\frac{k+\sqrt{l}}{m}[/tex]
Now, you need to find [tex]m,k, \mbox{and } l[/tex].
[tex]m[/tex] should be pretty straightforward to get.
To find [tex]k[/tex] and [tex]l[/tex] you need to realize that the skier reaches his peak when [tex]x-k=0[/tex] so [tex]k[/tex] and [tex]l[/tex] are the horizontal and vertical distances to the *top* of the skiers jump - which you should be able to find easily.
Related to Trouble with Proof of Optimal Launch Angle
1. What is the optimal launch angle for a rocket?
The optimal launch angle for a rocket depends on several factors, such as the desired trajectory, payload weight, and atmospheric conditions. Generally, a launch angle between 45-60 degrees is considered ideal for achieving maximum altitude and distance.
2. Why is the optimal launch angle important?
The optimal launch angle is important because it affects the trajectory and performance of the rocket. Launching at an incorrect angle can result in the rocket not reaching its intended destination or failing to achieve its desired altitude.
3. How is the optimal launch angle determined?
The optimal launch angle is determined through mathematical calculations and simulations. Factors such as the rocket's thrust-to-weight ratio, air resistance, and desired trajectory are taken into account to calculate the most efficient launch angle.
4. Can the optimal launch angle change for different rockets?
Yes, the optimal launch angle can vary for different rockets depending on their design, propulsion systems, and intended purpose. For example, a rocket designed for suborbital flight may have a different optimal launch angle than one designed for orbital flight.
5. What are some challenges in determining the optimal launch angle?
Some challenges in determining the optimal launch angle include unpredictable weather conditions, changes in atmospheric density, and the complexity of mathematical calculations involved. Additionally, human error and technical malfunctions can also affect the accuracy of the calculated optimal launch angle.
