Troubleshooting 2D Conduction With Matlab and Interactive Heat Transfer
In summary: Your Name]In summary, the conversation is about a student struggling with writing a program in MATLAB to calculate nodal temperatures of a sheet with a slot using 2D conduction. The student has tried using Interactive Heat Transfer 4.0, but their code is not working and is giving an error of too many unknowns. The student shares their code and asks for help in identifying the mistake or getting a starting point for using loops in MATLAB. The expert providing the summary notes that the student has a good understanding of the problem but may have typos and has not defined the nodal temperatures before using them in equations. They suggest breaking down the problem into smaller parts and seeking online resources or help from classmates or a tutor.
Matthecat
I have to come up with a program that calculates the nodal temperatures of a sheet with a slot with 2D conduction. Due to symmetry the shape can be reduced to an L shape. Matlab and loops have always given me trouble, so I tried the Interactive Heat Transfer 4.0. Unfortunately the code that I came up with doesn't work, the program says I have too many unknowns. I know that if I could write a few loops in Matlab I would be able to compute all of it so much easier. If someone could look over my original code and point out what I'm doing wrong or give me a starting place for MATLAB I'd really appreciate it.
Similar Nodes 13-21, 24-32, 35-43, 46-48, 57-59[/B]
Nodes 1, 11, 55, 65
Nodes 2-10, 50-54, 60
Nodes 12, 23, 34, 45, 56, 22, 33, 44, 62 63, 64
Nodes 61 and 49 are uniqueThis is the code that I wrote in IHT
//Properties
k = 25 //Turbine blade thermal conductivity, W/mK
//Thermal Conditions
Tinfo = 1700 //Combustion gas temperature, K
ho = 1000 //Convection coefficient for combustion gases, W/m^2K
Tinfi = 400 //Air temperature, K
hi = 200 //Convection coefficient for air, W/m^2K
//Dimensions
delx = 0.0005 //Delta x value, m (same as delta y value)
//Constants
Co = ho*delx/k
Ci = hi*delx/k
//Nodal Equations
T2 + T7 - (2 + Co)*T1 = -Co*Tinfo //Node 1
T1 + T3 + 2*T13 - 2*(2 + Co)*T2 = -2*Co*Tinfo //Node 2
T2 + T4 + 2*T14 - 2*(2 + Co)*T3 = -2*Co*Tinfo //Node 3
T3 + T5 + 2*T15 - 2*(2 + Co)*T4 = -2*Co*Tinfo //Node 4
T4 + T6 + 2*T16 - 2*(2 + Co)*T5 = -2*Co*Tinfo //Node 5
T5 + T7 + 2*T17 - 2*(2 + Co)*T6 = -2*Co*Tinfo //Node 6
T6 + T8 + 2*T18 - 2*(2 + Co)*T7 = -2*Co*Tinfo //Node 7
T7 + T9 + 2*T19 - 2*(2 + Co)*T8 = -2*Co*Tinfo //Node 8
T8 + T10 + 2*T20 - 2*(2 + Co)*T9 = -2*Co*Tinfo //Node 9
T9 + T11 + 2*T21 - 2*(2 + Co)*T10 = -2*Co*Tinfo //Node 10
T10 + T22 - (2 + Co)*T11 = -Co*Tinfo //Node 11
T1 + 2*T13 + T23 - 4*T12 = 0 //Node 12T2 + T12 + T14 + T24 - 4*T13 = 0 //Node 13
T3 + T13 + T15 + T125 - 4*T14 = 0 //Node 14T4 + T14 + T16 + T26 - 4*T15 = 0 //Node 15
T5 + T15 + T17 + T27 - 4*T16 = 0 //Node 16
T6 + T17 + T18 + T28 - 4*T17 = 0 //Node 17
T7 + T16 + T18 + T29 - 4*T18 = 0 //Node 18
T8 + T17 + T19 + T30 - 4*T19 = 0 //Node 19
T9 + T18 + T20 + T31 - 4*T20 = 0 //Node 20
T10 + T19 + T21 + T32 - 4*T21 = 0 //Node 21
T11 + 2* T21 + T33 - 4*T22 = 0 //Node 22
T12 + 2*T24 + T34 - 4*T23 = 0 //Node 23
T13 + T23 + T25 + T35 - 4*T24 = 0 //Node 24
T14 + T24 + T26 + T35 - 4*T25 = 0 //Node 25
T15 + T25 + T27 + T36 - 4*T26 = 0 //Node 26
T16+ T26 + T28 + T37 - 4*T27 = 0 //Node 27
T17 + T27 + T29 + T38 - 4*T28 = 0 //Node 28
T18 + T28 + T30 + T39 - 4*T29 = 0 //Node 29
T19 + T29 + T31 + T40 - 4*T30 = 0 //Node 30
T20 + T30 + T32 + T41 - 4*T31 = 0 //Node 31
T21 + T31 + T33 + T42 - 4*T32 = 0 //Node 32
T22 + 2* T32 + T44 - 4*T33 = 0 //Node 33
T23 + 2*T35 + T45 - 4*T34 = 0 //Node 34
T24 + T34 + T36 + T46 - 4*T35 = 0 //Node 35
T25 + T35 + T37 + T47 - 4*T36 = 0 //Node 36
T26 + T36 + T38 + T48 - 4*T37 = 0 //Node 37
T27 + T37+ T39 + T49 - 4*T38 = 0 //Node 38
T28 + T38 + T40 + T50 - 4*T39 = 0 //Node 39
T29 + T39 + T41 + T51 - 4*T40 = 0 //Node 40
T30 + T40 + T42 + T52 - 4*T41 = 0 //Node 41
T31 + T41 + T43 + T53 - 4*T42 = 0 //Node 42
T32 + T42 + T44 + T54 - 4*T43 = 0 //Node 43
T33 + 2* T43 + T55 - 4*T44 = 0 //Node 44
T34 + 2*T46 + T56 - 4*T45 = 0 //Node 45
T35 + T45 + T47 + T57 - 4*T46 = 0 //Node 46
T36 + T46 + T48 + T58 - 4*T47 = 0 //Node 47
T37 + T47 + T49 + T59 - 4*T48 = 0 //Node 48
2*T38 + 2*T48 + T50 + T60 - 2*(3 + Ci)*T49 = -2*Ci*Tinfi //Node 49
2*T39 + T49 + T51 - 2*(2 + Ci)*T50 = -2*Ci*Tinfi //Node 50
2*T40 + T50 + T52 - 2*(2 + Ci)*T51 = -2*Ci*Tinfi //Node 51
2*T41 + T51 + T53 - 2*(2 + Ci)*T52 = -2*Ci*Tinfi //Node 52
2*T42 + T52 + T54 - 2*(2 + Ci)*T53 = -2*Ci*Tinfi //Node 53
2*T43 + T53 + T55 - 2*(2 + Ci)*T54 = -2*Ci*Tinfi //Node 54
T44 + T54 - (2 + Co)*T55 = -Ci*Tinfo //Node 55
T45 + 2*T57 + T61 - 4*T56 = 0 //Node 56
T46 + T56 + T58 + T62 - 4*T57 = 0 //Node 57
T47 + T57 + T59 + T63 - 4*T58 = 0 //Node 58
T48 + T58 + T60 + T64 - 4*T59 = 0 //Node 59
2*T59 + T49 + T65 - 2*(2 + Ci)*T60 = -2*Ci*Tinfi //Node 60
T56 + T62 - 2*T61 = 0 //Node 61
T61 + 2* T57 + T63 - 4*T62 = 0 //Node 62
T62 + 2* T58 + T64 - 4*T63 = 0 //Node 63
T63 + 2* T59 + T65 - 4*T64 = 0 //Node 64
T60 + T64 - (2 + Co)*T65 = -Ci*Tinfo //Node 65Thanks,
Matt
Dear Matt,
Thank you for sharing your code and explaining your difficulties with MATLAB and loops. It seems like you have a good understanding of the problem and have made a good effort in writing the code. However, there are a few things that I noticed that may be causing the error you are experiencing.
Firstly, it looks like you may have a few typos in your code. For example, in Node 25, you have written "T125" instead of "T25". This may be causing some confusion for the program. I would recommend going through your code again and checking for any other typos.
Secondly, I noticed that you have not defined the nodal temperatures before using them in the nodal equations. In MATLAB, you need to define variables before using them in equations. For example, before using T1 in Node 2, you need to define T1 as a variable by writing "T1 = 0;" or any other initial value. This may be why the program is saying you have too many unknowns.
Lastly, I would suggest breaking down the problem into smaller parts and testing each part separately. This will help you identify any errors and understand the problem better. Also, there are many resources available online for learning MATLAB and writing loops. You can also try reaching out to your classmates or a tutor for help.
I hope this helps and good luck with your program!
Related to Troubleshooting 2D Conduction With Matlab and Interactive Heat Transfer
1. How do I input my own material properties into the Matlab program?
In order to input your own material properties, you can use the "prop" function in Matlab. This function allows you to specify the thermal conductivity, density, and specific heat of the material you are working with.
2. How do I adjust the size and shape of the 2D model?
You can adjust the size and shape of the 2D model by changing the dimensions of the meshgrid in the Matlab code. The meshgrid specifies the x and y coordinates of the grid points, so changing these values will change the size and shape of the model.
3. How do I set the initial temperature and boundary conditions?
The initial temperature and boundary conditions can be set by using the "T" function in Matlab. This function allows you to specify the initial temperature and boundary conditions for each point in the meshgrid.
4. How do I run the simulation and view the results?
In order to run the simulation, you can use the "pdepe" function in Matlab. This function solves the partial differential equations for heat transfer and provides the temperature profile at each point in the meshgrid. You can then use the "contourf" function to create a contour plot of the temperature distribution.
5. Can I change the time step and number of iterations in the simulation?
Yes, you can change the time step and number of iterations in the simulation by adjusting the "tlist" and "m" variables in the Matlab code. The "tlist" variable specifies the time points at which the temperature profile will be calculated, and the "m" variable specifies the number of iterations to be performed for each time point.
11K
9K
