Troubleshooting a Simple Problem: Tips & Tricks
In summary, the formula for the volume of a cube is V=s^3 and when differentiating with respect to time t, we get dV/dt=3s^2(ds/dt). After plugging in the given data and considering units, we find that the rate of change of the volume with respect to time is 72 cm^3/sec for s=2 cm and 1800 cm^3/sec for s=10 cm. This aligns with the formula and the units make sense.
karush
MHB
3,269
I know this is a simple problem but new at it. answer not in book so hope correct.
Re: expanding cube
You have the formula for volume:
\(\displaystyle V=s^3\)
Differentiating with respect to time $t$, we find:
\(\displaystyle \frac{dV}{dt}=3s^2\frac{ds}{dt}\)
Now plug in the given data...and keep in mind your units...you should get \(\displaystyle \frac{\text{cm}^3}{\text{s}}\)
Re: expanding cube
$$3\cdot 2^2 \cdot 6 = 72 \text { cm}^3\text{/ sec}$$
and
$$3\cdot 10^2 \cdot 6 = 1800 \text { cm}^3\text{/ sec}$$
Re: expanding cube
and
Looks good. If you wish to be absolutely clear on an exam, I would write (in addition to showing your differentiation with respect to $t$ to obtain the formula):
a) \(\displaystyle \left. \frac{dV}{dt} \right|_{s=2\text{ cm}}=3\left(2\text{ cm} \right)^2\left(6\,\frac{\text{cm}}{\text{s}} \right)=72\,\frac{\text{cm}^3}{\text{s}}\)
b) \(\displaystyle \left. \frac{dV}{dt} \right|_{s=10\text{ cm}}=3\left(10\text{ cm} \right)^2\left(6\,\frac{\text{cm}}{\text{s}} \right)=1800\,\frac{\text{cm}^3}{\text{s}}\)
Re: expanding cube
makes sense
I will post some more to see how close I am
FAQ: Troubleshooting a Simple Problem: Tips & Tricks
How do I determine the cause of a simple problem?
To troubleshoot a simple problem, start by identifying the symptoms and gathering information about the problem. Then, try to replicate the issue and narrow down potential causes. Finally, test each potential cause until you find the one that is causing the problem.
What should I do if I can't solve the problem on my own?
If you are unable to solve the problem on your own, consider seeking help from a colleague or consulting online resources. It's also helpful to document your troubleshooting process so that you can share it with others who may be able to assist you.
How can I prevent simple problems from occurring in the future?
To prevent simple problems from occurring, it's important to regularly maintain and update your equipment and software. It's also helpful to keep a record of any problems that have occurred in the past and the solutions you used to solve them.
What are some common mistakes people make when troubleshooting simple problems?
Some common mistakes people make when troubleshooting simple problems include skipping steps, not thoroughly testing potential causes, and not seeking help when needed. It's important to approach troubleshooting systematically and to be open to trying different solutions.
How can I become better at troubleshooting simple problems?
Becoming better at troubleshooting simple problems takes practice and experience. It's important to stay organized, document your process, and learn from past experiences. Additionally, familiarizing yourself with common troubleshooting techniques and resources can also improve your skills.
