Troubleshooting Indeterminate Limits in Calculus
  • MHB
  • Thread starter phrox
  • Tags
    Limit
In summary, the equation for a) is that H - 1/x = (sqrt(1/x^2)+1) - sqrt(1/x^2) and for b) it says to compute the limit as x-> 0, which is not possible because all the x's are under 1.
phrox
40
http://i1301.photobucket.com/albums/ag115/phrox1/additional_zps10bf2373.png
That's the question ^^,
So I came up with H = sqrt(D^2 + 1)
Then I got
H - D = (sqrt(1/x^2)+1) - D
Annndd then:
I have no clue where to go from here, any help is appreciated!
So did is my equation for a) H - 1/x = (sqrt(1/x^2)+1) - sqrt(1/x^2)
and for b) it says instead, compute the limit as x-> 0, which would make it not work because all the x's are under ones, making them undefined.
So far so good. Have you covered how to use L'Hopital's rule for the indeterminant form [tex]\infty - \infty[/tex]?
-Dan
no I haven't covered L'Hospital's rule, also I can't directly sub x->0 into this because it just won't work, undefined.
Well, okay. I'll leave the final word to someone who knows limits better than me, but here's a "hand waving" argument.
For small x, 1/x^2 gets very large. So large that we can ignore the 1 in the first expression:
\(\displaystyle \frac{1}{x^2} + 1 \to \frac{1}{x^2}\)
so
\(\displaystyle \lim_{x \to 0} \left ( \sqrt{\frac{1}{x^2} + 1} - \sqrt{\frac{1}{x^2}} \right ) \to \sqrt{\frac{1}{x^2}} - \sqrt{\frac{1}{x^2}} = 0\)
-Dan
Very well!... what You have to do is to evaluate...
$\displaystyle l= \lim_{x \rightarrow 0} \sqrt{1 + \frac{1}{x^{2}}} - \sqrt{\frac{1}{x^{2}}}\ (1)$
Now You can consider that...
$\displaystyle \sqrt{1 + \frac{1}{x^{2}}} - \sqrt{\frac{1}{x^{2}}} = (\sqrt{1 + \frac{1}{x^{2}}} - \sqrt{\frac{1}{x^{2}}})\ \frac{\sqrt{1 + \frac{1}{x^{2}}} + \sqrt{\frac{1}{x^{2}}}}{\sqrt{1 + \frac{1}{x^{2}}} + \sqrt{\frac{1}{x^{2}}}}= \frac{1}{\sqrt{1 + \frac{1}{x^{2}}} + \sqrt{\frac{1}{x^{2}}}}\ (2)$
... and the 'indeterminate form' disappared...
Kind regards
$\chi$ $\sigma$
topsquark said:
\(\displaystyle \sqrt{\frac{1}{x^2}} - \sqrt{\frac{1}{x^2}} = 0\)
-Dan
You can not remove the limit because it is still indeterminate form . You can not simply cancel .
I'm guessing you can't do it simply this way? http://s1301.photobucket.com/user/phrox1/media/image001_zps75e88aa9.jpg.html?sort=3&o=0
No you can't, because the expression $\infty - \infty$ is not defined. What you can do is to use the trick in chisigma's comment above, to write the limit as \(\displaystyle \lim_{x\to0}\left( \frac{1}{\sqrt{1 + \frac{1}{x^{2}}} + \sqrt{\frac{1}{x^{2}}}}\right).\) Multiply top and bottom of that fraction by $x$, so that it becomes \(\displaystyle \lim_{x\to0}\left( \frac{x}{\sqrt{x^2 + 1} + 1}\right).\) In that fraction, the numerator goes to $0$ as $x\to0$, but the denominator goes to $2$. So the fraction has limit $\dfrac02 = 0.$
Thanks a ton, I just find it so weird thinking of x as in sqrt(x^2) and etc. Wish I had time to practice limits instead of getting an assignment as soon as I'm finished the last lol.
I really should have written it as
\(\displaystyle \lim_{x \to 0} \left ( \sqrt{ \frac{1}{x^2} } - \sqrt{ \frac{1}{x^2} } \right )\)
but I did say it was "hand waving"...
-Dan
FAQ: Troubleshooting Indeterminate Limits in Calculus
What is an odd limit?
An odd limit is a mathematical concept that refers to the value that a sequence of numbers approaches as the number of terms in the sequence increases. In other words, it is the value that the sequence gets closer and closer to, but never quite reaches, as more terms are added.
Why might an odd limit give me troubles?
An odd limit can give you troubles if the sequence does not have a clearly defined limit or if there are errors in your calculations. Additionally, some mathematical operations may not be able to be performed on sequences with odd limits, making it difficult to solve certain problems.
How do I find the odd limit of a sequence?
To find the odd limit of a sequence, you can either use a formula or a graphing calculator. If a formula is not available, you can also manually calculate the limit by finding the pattern in the sequence and seeing what value it approaches as more terms are added.
Can an odd limit be a negative number?
Yes, an odd limit can be a negative number. The limit of a sequence is not restricted to only positive numbers. It is simply the value that the sequence approaches as the number of terms increases, regardless of whether it is positive, negative, or zero.
What are some real-world applications of odd limits?
Odd limits are used in various fields of science and engineering, such as physics, biology, and economics. For example, in physics, odd limits are used to calculate the velocity of an object as it approaches the speed of light. In economics, odd limits can be used to determine the maximum profit that a company can achieve by producing and selling a certain product.
