Troubleshooting of WFE - (Wiped Film Evaporator)
In summary, troubleshooting a Wiped Film Evaporator (WFE) involves identifying and resolving common issues that can affect its performance. Key areas to focus on include temperature control, feed flow rates, and potential blockages or leaks. Regular maintenance, monitoring of operational parameters, and understanding the specific characteristics of the material being processed are essential for ensuring optimal efficiency. Additionally, addressing mechanical failures or malfunctions promptly can prevent extended downtime and enhance the overall effectiveness of the evaporator system.
Rachit
TL;DR Summary
Continuous boiloff operation in WFE.
Feed Details :
Component X : 80% ( Boiling point : 105 deg.C)
Component Y : 20% ( Boiling point : 256 deg.C)
Feed Rate : 600 kg/hr
Heating medium : Steam @ 145 deg.C
operating condition : 50 Torr, 90 deg.C ( Based on Aspen Flash Simulation).
Desired Outcome :
TO remove 99% of component X from Component Y.
History :
Earlier this operation was performed in batch mode. Where all of component X was boiled off.
During this, Bottom mass temperature was observed to go upto 120 deg.C uder 50 torr of vacuum.
No component Y was observed in the top distillate - throughout the operation.
Current Scenario :
Observations in WFE :
  1. In top distillate component Y is found ~10%.
  2. In bottom residue component Y is found ~80%.
  3. At 50 torr vacuum, operating temperature is only 40 deg.C.
  4. Upon increasing flowrate, component Y is found less in top distillate.
What should be done to minimize loss of component Y in top distillate ?
Have you tried to model this operation? Is the solution ideal so that Raoult's Law can be applied.
The solution is not ideal, but I have modeled the operation in Aspen plus and component Y in top distillate is ~0.5% w/w.
The first step is to determine why your model is not matching the observed split. What are your thoughts on this? How do other observational measurements compare with model predictions? How confident are you in the VLE part of the model?
My friend
Aspen Plus has a set of properties packages that will approach the simulation to the real process. It has a tutorial to select the best ones. However, you have to select PR if your components do not have a polar behavior.
To optimize the process, it could be done with the process data. Of course, anyone needs to know X and Y, to have a view of the distillation equilibrium of the mix. Simulation is a tool, just that; but trained process engineers should do it by analyzing the field process data.
Horacio
FAQ: Troubleshooting of WFE - (Wiped Film Evaporator)
Why is my Wiped Film Evaporator not reaching the desired vacuum level?
There are several reasons why your Wiped Film Evaporator (WFE) might not be reaching the desired vacuum level. Common issues include leaks in the system, an improperly functioning vacuum pump, or blockages in the vacuum line. Check all seals and connections for leaks, ensure the vacuum pump is operating correctly, and clean any blockages in the vacuum line.
What could be causing poor separation efficiency in my WFE?
Poor separation efficiency can be caused by several factors, including incorrect operating temperatures, improper feed rate, or issues with the wiped film distribution. Make sure the temperature settings are optimized for the compounds being separated, adjust the feed rate to ensure it is within the optimal range, and inspect the wiper blades and film distribution system for any malfunctions or buildup.
How do I resolve uneven film distribution inside my WFE?
Uneven film distribution can lead to inefficient separation and product degradation. To resolve this, check the condition and alignment of the wiper blades, ensure the feed material is being introduced evenly, and verify that the rotor speed is set correctly. Regular maintenance and cleaning of the wiper system can also help maintain even film distribution.
Why is my WFE experiencing excessive fouling?
Excessive fouling in a WFE can be caused by impurities in the feed material, incorrect operating temperatures, or insufficient cleaning. To address this, ensure the feed material is properly pre-treated or filtered, operate the WFE within the recommended temperature range, and implement a regular cleaning schedule to prevent buildup.
What should I do if the WFE is producing an off-spec product?
If the WFE is producing an off-spec product, first check the operating parameters such as temperature, feed rate, and vacuum level to ensure they are within the desired range. Additionally, inspect the feed material for consistency and purity, and verify that the wiper blades and other internal components are functioning correctly. Adjustments to the operating conditions and regular maintenance can help achieve the desired product specifications.
