Trucks travels beneath an airplane .
  • Thread starter ArcherofScience
  • Tags
    Airplane
In summary, a truck travels beneath an airplane that is moving at 180 km/h at an angle of 39 degrees to the ground. To stay beneath the airplane, the truck must travel at a speed of approximately 139.8863 km/h. The magnitude of the vertical component of the airplane's velocity is 113.2777 km/h. The direction of the vectors does not affect the answer to the questions posed in the problem.
ArcherofScience
36
trucks travels beneath an airplane...
A truck travels beneath an airplane that is
moving 180 km/h at an angle of 39 to the
ground. How fast must the truck travel to stay be-
neath the airplane? What is the magnitude of the vertical component of the velocity of the plane? Answer in units of km/h
My physics teacher said the question is identifying the horizontal and vertical components. So I had to do Vcostheta and Vsintheta.
Vcostheta=180cos39=139.8863 km/h
vsintheta=180sin39=113.2777 km/h
my problem is, I don't understand which direciton the vectors are. Is it going north of east or south of east, or what? I can't identify them in the problem and I can't tell if the answers need a negative sign or positive sign.
The problem is only asking you questions like "How fast" and "magnitude of". Those are questions where the answer is always positive. You can pick a direction for things to be traveling in if it helps you picture things but it shouldn't affect your answer.
ohh ok. i see. thanks :)...i have another question from my hw...is it ok to ask it on this same thread?
Its ok. But it will probably get more attention if you post it in a new thread.
As a scientist, it is important to clarify the direction of vectors in a problem. In this case, we can assume that the airplane is moving towards the east, as this is the most common direction for airplanes to travel. Therefore, the horizontal component of the airplane's velocity would be positive, and the vertical component would be negative.
To determine the speed at which the truck must travel to stay beneath the airplane, we can use the Pythagorean theorem. The magnitude of the airplane's velocity can be found using the horizontal and vertical components:
Vplane = √(Vcosθ)^2 + (Vsinθ)^2
= √(180cos39)^2 + (180sin39)^2
= 180 km/h
Since the truck needs to travel at the same speed as the airplane, its velocity would also be 180 km/h. However, the direction of the truck's velocity would depend on the angle at which it is traveling relative to the airplane's direction.
To calculate the magnitude of the vertical component of the airplane's velocity, we can use the equation Vsinθ:
Vvertical = Vsinθ
= 180sin39
= 113.2777 km/h
Therefore, the vertical component of the airplane's velocity is 113.2777 km/h.
In summary, to stay beneath the airplane, the truck would need to travel at a speed of 180 km/h in the same direction as the airplane. The magnitude of the vertical component of the airplane's velocity is 113.2777 km/h.
FAQ: Trucks travels beneath an airplane .
1. What is the purpose of trucks traveling beneath an airplane?
The purpose of trucks traveling beneath an airplane is to transport luggage and cargo from the airport terminal to the aircraft. This process is known as ground handling and helps to ensure that all necessary items are loaded onto the plane before takeoff.
2. Are there any safety concerns with trucks traveling beneath an airplane?
Yes, there are strict safety protocols in place to ensure the safety of both the ground crew and the aircraft. The trucks are required to maintain a safe distance from the plane and follow designated paths. The ground crew also undergoes extensive training to ensure proper handling and loading procedures.
3. How do the trucks communicate with the airplane crew?
The trucks typically communicate with the airplane crew through designated radio channels. The ground crew will receive instructions from the cockpit crew and communicate any updates or issues as needed.
4. Can trucks travel beneath an airplane during flight?
No, trucks are not allowed to travel beneath an airplane during flight. This would be a safety hazard and could potentially cause damage to the aircraft. Trucks only travel beneath an airplane while it is parked at the gate or taxiing on the ground.
5. Are there any alternative methods for transporting luggage and cargo to an airplane?
Yes, there are alternative methods such as using conveyor belts or loading the items directly from the airport terminal onto the plane. However, trucks are still the most common and efficient method for ground handling at most airports.
