True/False: Qualitative Thermodynamics Question
In summary: More efficient when operated between the same temperatures? Yes. More efficient when operated between different temperatures? No.9) All heat engines operating between the same temperatures have the same efficiency False. Efficiency depends on the cycle.10)Adiabatic expansion will lower the temperature of a gas True11) True12) True.
yaylee
Which of the following statements about entropy and heat engines are true? (There is more than one right answer!)
1)The entropy of the universe can never decrease
2) The COP (coefficient of performance) of a refrigerator can never be greater than 1
3) All Carnot engines are reversible
4) A refrigerator lowers the entropy of the volume inside
5) If the temperature of the cold reservoir increases with the temperature of the hot reservoir unchanged, the efficiency of a Carnot engine will increase
6) Any process that includes adding heat to an ideal gas will increase the entropy of the gas
7)It is impossible have a net transfer of heat from a cold reservoir to a warm reservoir
8) All Carnot engines are more efficient than all real engines
11) The entropy of a system can never decrease
12) The efficiency of a Carnot engine can never be 1
Entropy = dQ/T
efficiency of Carnot Engine = 1 - (Tc/Th), where Tc = Temp of cold reservoir, Th = hot.
Coefficient of Performance C.O.P = Qc/W, where Qc = heat absorbed into cold reservoir
Work done in ANY cycle, W = Qh - Qc.
Note: I bolded the correct answer, with explanation below the correct statement!
By definition, entropy will be equal to 0 in a Carnot cycle, greater than 0 in a real cycle..
By definition, Carnot engines are quasi-static, reversible processes.
Decreasing entropy is analagous to saying you are "removing heat" from the refrigerator.
e = 1 - Tc/Th. Increasing Tc will decrease e.
By definition, dS = +dQ/T, so dS is positive.
Simple definition.
Simple definition.
At absolute zero, this will be true.
Pls point out where I may have missed a true statement, or marked a true statement which is actually false. Many thanks in advance for your help! Infinite appreciation !
1) True, because it’s the whole system.
2) False. http://wiki.answers.com/Q/Why_coefficient_of_performance_of_a_refrigerator_is_greater_than_1
3)True
4)True
5)True. Imagine the difference between a refridgerator and a freezer.
6) "Yes, thermodynamically. In statistical mechanics heat increases the number of microstates and thus entropy which is proportional to their log." quoted from anna v, http://physics.stackexchange.com/q/47435/11833
You can refer to this too https://www.physicsforums.com/showthread.php?t=177049
7)False. That’s what refridgerators do.
8)True.
9)False. For example, Carnot is the most efficient.
10) True. In adiabiatic, [tex]Q=0, TV^{\gamma -1}=constant[/tex] and [tex]PV^{\gamma }=constant[/tex ]
11) True
12)True. Your explanation is wrong: (When [tex]T_c[/tex] is) At absolute zero, this will be false.
All your true/false is correct. Lol why do you even ask.
My answers are in italics:
1)The entropy of the universe can never decrease. True
2) The COP (coefficient of performance) of a refrigerator can never be greater than 1 False
3) All Carnot engines are reversible True or False depending on whether you include external mechanical irreversibility. An engine operating on the Carnot cycle but whose output work is dissipated due to friction is not reversible.
4) A refrigerator lowers the entropy of the volume inside True
5) If the temperature of the cold reservoir increases with the temperature of the hot reservoir unchanged, the efficiency of a Carnot engine will increase False. Efficiency will decrease (Efficiency = 1-Tc/Th).
6) Any process that includes adding heat to an ideal gas will increase the entropy of the gas True
7)It is impossible have a net transfer of heat from a cold reservoir to a warm reservoir True or False, depending on what it means by "net" transfer of heat. If "net" refers to the transfer of heat in the Clausius statement of the second law: "No process is possible whose sole result is the transfer of heat from a body of lower temperature to a body of higher temperature.", then the statement is true. .
8) All Carnot engines are more efficient than all real engines False. It depends on the temperatures the engines operate between.
9) All heat engines operating between the same temperatures have the same efficiency False. This is true only for all Carnot engines operating between the same temperatures
10)Adiabatic expansion will lower the temperature of a gas False. An adiabatic free expansion of an ideal gas results in no change in temperature.
11) The entropy of a system can never decrease False. The entropy of the system + surroundings can never decrease
12) The efficiency of a Carnot engine can never be 1True but it can get arbitrarily close to 1 as Tc → 0K. Absolute 0 is unattainable even in theory.
AM
Related to True/False: Qualitative Thermodynamics Question
1. What is qualitative thermodynamics?
Qualitative thermodynamics is a branch of thermodynamics that focuses on the principles and concepts of thermodynamics rather than mathematical calculations. It involves understanding the behavior of systems and how they interact with their surroundings based on the laws of thermodynamics.
2. What is the difference between qualitative and quantitative thermodynamics?
The main difference between qualitative and quantitative thermodynamics is that qualitative thermodynamics focuses on the principles and concepts while quantitative thermodynamics involves mathematical calculations and modeling to analyze and predict the behavior of systems.
3. How is qualitative thermodynamics applied in real-life situations?
Qualitative thermodynamics is applied in various fields such as environmental science, engineering, and materials science. It helps in understanding the behavior of energy and matter in natural and man-made systems, and how they can be optimized for efficient use.
4. What are the key principles of qualitative thermodynamics?
The key principles of qualitative thermodynamics are the laws of thermodynamics, which include the conservation of energy, the increase of entropy, and the impossibility of achieving absolute zero temperature. These principles govern the behavior of energy and matter in different systems.
5. How can qualitative thermodynamics benefit society?
Qualitative thermodynamics can benefit society by providing a deeper understanding of energy and matter in different systems, which can lead to the development of more efficient and sustainable technologies. It also helps in solving environmental issues and improving the overall quality of life.
