True or False Integral Calculus Question #3
In summary, if $f(x)$ is a negative function that satisfies $f'(x) > 0$ for $0 \le x \le 1$, then the right hand Riemann sums will always yield an underestimate of $\int_{0}^{1} (f(x))^2\,dx$. This is because the squared function will turn $f(x)$ into a positive, increasing function, making the right hand sums an overestimate.
MermaidWonders
112
True or False: If $f(x)$ is a negative function that satisfies $f'(x) > 0$ for $0 \le x \le 1$, then the right hand sums always yield an underestimate of $\int_{0}^{1} (f(x))^2\,dx$.
- - - Updated - - -
Would it be true since right hand Riemann sums for a negative, increasing function will always produce an underestimate for the integral, so it doesn't really matter if the entire "function" we're dealing with is squared?
$(f(x))^2\ge0$
Or... would it be that squaring $f(x)$ will turn $f(x)$ into a positive function from a negative function, so the statement is going to be false because taking the right Riemann sum will still give you an overestimate for positive, increasing functions?
Yeah, OK. So, in that case, it becomes a positive, increasing function, so it's an overestimate, right?
That's right.
FAQ: True or False Integral Calculus Question #3
1. What is the difference between a true and false integral calculus question?
A true integral calculus question requires the use of integral calculus methods to solve the problem and arrive at the correct answer. A false integral calculus question may use integral calculus terminology or notation, but does not actually require the use of integral calculus methods to solve it.
2. How can I identify if a question is a true or false integral calculus question?
Look for key phrases or terms such as "find the integral of," "evaluate the integral," or "using integration." If the question requires the use of integral calculus methods, it is likely a true integral calculus question. If it only uses integral calculus terminology without requiring the use of integral calculus methods, it is likely a false integral calculus question.
3. Can a true integral calculus question have a false answer?
No, a true integral calculus question should have a correct answer that can be solved using integral calculus methods. If the question leads to an incorrect or impossible answer, it is likely a false integral calculus question.
4. Are there any tips for solving true or false integral calculus questions?
Start by carefully reading the question and identifying if it requires the use of integral calculus methods. Then, use your knowledge of integral calculus rules and techniques to solve the problem step-by-step. If you are unsure, it can be helpful to check your answer using a calculator or asking a teacher or tutor for assistance.
5. Can I use a calculator to solve true or false integral calculus questions?
In most cases, yes. However, it is important to check with your teacher or professor to see if they have any specific guidelines or restrictions on using a calculator for integral calculus problems. It is also important to understand how to set up the problem and interpret the calculator's output correctly.
