True or false? |z|^2 is an entire function
  • Thread starter docnet
  • Tags
    Function
In summary, it was discussed that the absolute value function is not analytic wherever its argument equals zero. It was also mentioned that ##f## is not analytic at ##z=0##, therefore it is not entire. However, it was pointed out that in general, if ##f(z) = f_1(z) + f_2(z)##, then even if ##f_1## and ##f_2## are not analytic, their sum may be. It was suggested that the non-analytic behavior of the individual functions may cancel each other out. It was then noted that the absolute value function has a formal definition of ##|z|=\sqrt{z\bar{z}}## and that it is real and
docnet
486
False
The reasoning for answer:
The absolute value function is is not analytic wherever its argument equals zero. ##f## is not analytic at ##z=0## so it is not entire.
docnet said:
Homework Statement:: .
Relevant Equations:: .
False
That's a fairly significant logical fallacy!
In general, if ##f(z) = f_1(z) + f_2(z)##, then even if ##f_1## and ##f_2## are not analytic, their sum may be. Intuitively, the non-analytic behaviour of ##f_1## and ##f_2## may cancel each other out in some way.
Likes docnet and S.G. Janssens
What can you say about the zeros of ##f## in the complex plane?
Likes docnet
really? that is surprising to me.
Take as an example: $$f(z) = z = Re(z) +iIm(z)$$ is the sum of two non-analytic functions!
Likes docnet
the zeroes of ##f## are given by $$|z|^2=2zRe(z)$$
the left size is real valued, so the right side has to be real valued. The equation ##x^2=2x^2## has no solutions other than ##x=0##, so the zero of ##f## is ##z=0##.
You have one thing a bit backwards: ##z=0## is actually the only point where ##|z|^2## is complex differentiable. You can verify this from the Cauchy Riemann equations.
And anyway, a function ##f## being (not) differentiable at a point doesn't mean the same is true for ##f+g.##
For your function, you can also write it in real and imaginary parts and see whether the Cauchy-Riemann equations hold.
Edit: Apologies, while I was writing this, several posts appeared that i didn't notice!
Likes docnet
okay.. that makes sense
How do you tell the real and imaginary parts of ##z## in the absolute value function? this is what I wanted to do, compute the Cauchy Riemann equations, but the absolute value function confused me.
You know what I'm going to say ... you did the same thing again! You jumped at an easy, one-line proof, that you didn't seriously question. You must be able to fully justify each step you take.
Developing your maths skills means developing the ability to find the example I gave in post #5.
Likes docnet
Oh gosh.. I forgot that the absolute value function has a formal definition ##|z|=\sqrt{z\bar{z}}##. I'm so sorry @PeroK
The absolute value is real, it has no imaginary part.
Likes docnet
docnet said:
How do you tell the real and imaginary parts of in the value funciton? this is what I wanted to do, compute the Cauchy Riemann equations, but the absolute value funciton confused me.
You would write ##z=x+iy## (so ##\text{Re}(z)=x## and ##|z|^2=x^2+y^2##).
Likes docnet and PeroK
$$f=|z|^2-2zRe(z)=x^2+y^2-2(x+iy)x$$
$$=(y^2-x^2)-i(2xy)$$
$$v_x=-2x=u_y$$
$$-v_y=-2y=u_x$$
so ##f=|z|^2-2zRe(z)## satisfies the Cauchy Riemann equations and so it's entire.
Likes PeroK
Would you believe it!
Likes docnet
There goes my dreams for a Ph.D in maths, smashed to granules.
You'd certainly bash out a PhD thesis quickly enough. Whether it would be defensible is another matter! :smile:
  • Haha
Likes docnet
FAQ: True or false? |z|^2 is an entire function
What is an entire function?
An entire function is a complex-valued function that is defined and analytic in the entire complex plane.
What is the meaning of |z|^2 in the statement?
|z|^2 refers to the modulus or absolute value squared of the complex number z. In other words, it is the distance of z from the origin squared.
Can you give an example of an entire function?
One example of an entire function is f(z) = e^z, where e is the base of the natural logarithm.
How can you determine if a function is entire?
A function is entire if it is defined and analytic in the entire complex plane. This means that it must have a derivative at every point in the complex plane.
What is the significance of |z|^2 being an entire function?
If |z|^2 is an entire function, it means that it is defined and analytic in the entire complex plane. This also implies that it is a continuous and differentiable function in the complex plane, making it a useful tool in complex analysis and other areas of mathematics.
