Trying to buy quality EM meter and
In summary, the conversation discusses someone's concerns about EM field exposure near power lines and other sources, and their search for a measuring tool to evaluate the radiation. They also ask questions about recommended methods for measuring RF and low frequency radiation, the need for re-certification or re-calibration of meters, and the use of body volt meters. The conversation also touches on the difference between measuring magnetic field in 1 axis versus 3 axes, and the presence of noise on measurement screens. Anecdotes and articles are shared to provide further information and reassurance.
Miran
Hi all!
Not sure if this is the right place but I am having really hard time getting these questions answered in other places as well. I became interested in EM topic when power company decided to build a 2x110kV power line near my house. I would like to approach this problem rationally with measuring tools to determine how far the EM field can reach before it becomes indistinguishable form other present radiation. Upon reading more about it I also became more aware of other source, especially HF ones
inside my home and cell towers.
I began to search for a viable measuring tool and quickly realized that I'll need to buy several to cover different frequencies and radiation magnitudes. If I may, I would like to ask everyone here a few questions:
1. Why do experts recommend measuring RF with a single meter while low frequency radiation is measuring magnetic radiation separated from electrical field?
2. Am I required to re-certify or re-calibrate my meters every once in a while to assure that the accuracy is still decent? I am afraid that this might prove to be very costly, especially in my country.
3. Some recommend using body volt meter to measure the electric potential on the body itself? How does it compare with mid tier hand-held meters and how would one compare the measurements from both methods?
4. I noticed that pricier gauss meters measure magnetic field in all 3 axis, 3d basically. But I couldn't find one that does the same with electrical field. Why is it so and do I even need to measure it in 3d? If I measure in 1 axis, do I need to take 3 measurements and combine them?
5. What exactly does noise represents on the measurement screen (I noticed HF meters often include signal amplifier but not LF ones)?
I did email all of these questions to 2 re-sellers and 1 manufacturer and haven't received any replies in days even thou the meters in question were $500-$1000. I hope I can find some answers on this forum:)
Thank you all for your effort and time.
how far is near ?
stuff in your home is going to expose you to much more EM than power lines at a distance or cell towers
eg ... do you use an electric blanket to heat the bed in the winter time ?The 2 links @dlgoff has provided should belay your worries :smile:
Likes dlgoff
We had a thread last year about magnetic field from a three phase transmission line.
I think it might be of help
here it is
Ampere's law to calculate the B field from a balanced three-phase system
I can add an anecdote.
Recall that tap water is pretty conductive.
A good friend bought a band new house immediately adjacent a 230 kv power line. His back fence was right at the utility right of way.
When taking a shower in his upstairs bathroom he noticed a mild electric shock from the water.
He didn't mind the 'tingling' but his wife put her foot down and insisted he fix it.
He did measure a few volts between the shower head and drain ..
We discussed his measurements and decided there was some some sort of AC coupling, probably capacitive, into the water inside his PVC plumbing.
He notified the builder .
The builder had several more houses in progress alongside the same power line so wanted to nip that problem in the bud..
The builder removed the bathroom drywall and wired all the metal wall studs to the Earth ground rod at electric service entrance.
That fixed the "Shocking Shower". But i will never know why.
Point is
you might find an E-field that's feel-able as far out as a hundred feet
and measurable somewhat farther .
Look at that thread i mentioned above
for it shows that
once you're away by a distance of (several X the spacing between the phase wires),
the individual fields from the three phases very nearly cancel one another
so your total field drops to nil.
old jim
Likes dlgoff and davenn
Faraday shield comes to mind.
Likes jim hardy
Related to Trying to buy quality EM meter and
What is an EM meter and why is it important for a scientist to have one?
An EM meter, also known as an electromagnetic field meter, is a scientific instrument used to measure the strength and direction of electromagnetic fields. It is important for a scientist to have one because it allows them to collect data and conduct experiments related to electromagnetic phenomena.
How do I determine the quality of an EM meter?
The quality of an EM meter can be determined by looking at its accuracy, sensitivity, and range. A high-quality meter should have a low margin of error, be able to detect small changes in electromagnetic fields, and have a wide range of measurement capabilities.
What factors should I consider when buying an EM meter?
When buying an EM meter, you should consider its purpose, accuracy, sensitivity, range, and price. It is important to choose a meter that is suitable for your specific needs and budget.
Are there different types of EM meters and which one is the best?
Yes, there are various types of EM meters such as handheld meters, digital meters, and gaussmeters. The best type of meter depends on your specific needs and the type of electromagnetic fields you are measuring. It is recommended to do research and read reviews to determine the best meter for your purposes.
Where can I purchase a high-quality EM meter?
You can purchase a high-quality EM meter from scientific equipment suppliers, online retailers, or directly from the manufacturer. It is important to research the seller and make sure they are reputable and provide accurate product information.
  • Electrical Engineering
  • Classical Physics
