IanHathaway
- 6
Trying to determine the "Safe" properties of Face Guards
I work in a sports science laboratory and I've been set the task of trying to create a simple and inexpensive test to determine which face guards are safe when two field hockey players clash heads (one wearing a face guard the other unprotected). You have to excuse me if my question has a simple answer or if my terminology is a little out, its been many years since I've had to use physics in anger.
Here is the state of play so far:
Any suggestions would be most appreciated.
I have or can get data relating to injurys and what pressures can cause bone/facial damage. I am therefore looking to express a safety rateing based on pressure levels in combination with the hardness of material and shape of face guard. The last two items I can already determine but I'm struggling with the pressure part.
I can assess the pressure exerted using a pressure sensitive photo film easily enough but this method is not ideal because it is very expensive and only gives results for one or two points on each face guard.
A simpler and much cheaper method is to drop the face guard into clay and measure the depth of penetration. I know the kinetic energy at the point of impact and I can work out the impact force but I'm not sure how to convert this into a pressure value. I know this should be easy as pressure has a direct relationship between force and impact area but due to the shape of each face guard its not so easy working out what the impact area is.
