Trying to find the amount of stretch of a spring for a launch
In summary, the problem involves finding the stretch of a spring needed for it to launch itself into a trashcan located some distance away. The spring is located on the edge of a ramp that is 1.13 m high, with an angle of 30 degrees above horizontal. The spring constant is 175 N/m. The trashcan is located 5.85 m away, with height being ignored. The solution involves finding the initial velocity of the spring and using conservation of energy to determine the stretch required. However, the problem may be beyond the level of introductory physics due to the consideration of the mass of the spring.
Ace.
52
I'm doing an experiment where I have to calculate the stretch of a spring needed for it to launch itself into a trashcan located some distance away. The spring is located on the edge of a ramp that is 1.13 m high. The angle of the ramp is 30 degrees above horizontal. The spring constant of the spring is 175 N/m. The trashcan is located a horizontal distance 5.85 m away, height of the trashcan can be ignored. I must find the stretch (x) of the spring that will allow it to launch itself and land in the trashcan.
Ee = (1/2)kx^2
Ek = (1/2)mv^2
Eg = mgh
Fx = kx (spring equation)
At first I thought I must solve for time of flight but there are too many variables involved. For instance, I don't know the initial velocity of the spring. If I could solve for time, then I could use it to find Vx (horizontal component of velocity), and then use the angle to find V. Then I would do Ee = Ek (elastic potential was converted to kinetic the instant the spring was released) and finally solve for the stretch (x).
I tried to use the range equation: R = (v^2/g)sin2θ in hopes of finding V, but that is only for projectiles that land at the same height. Any guidance on how to approach this?
Think of the problem in two steps. First, see if you can find the magnitude of the velocity as the spring leaves the ramp. You know the velocity will be directed 30 degrees above the horizontal, and where the spring will land, so see if you can solve for v. You can eliminate the time variable with two equations.
Then think about how much work the spring has to do to give itself that initial velocity. If it has to move up the ramp first before leaving, you'll also have to involve the increase in potential energy.
After finding the required initial speed in the first step per jackarms hints, you then need to use conservation of energy to determine the spring stretch required. But since the object being launched is the spring itself, you need to know the mass of the spring, and the solution is perhaps beyond the intro physics level type spring problems which typically deal with massless springs.
Related to Trying to find the amount of stretch of a spring for a launch
What is the purpose of finding the amount of stretch of a spring for a launch?
The purpose of finding the amount of stretch of a spring for a launch is to determine the force and energy needed to launch an object using the spring, as well as to ensure the object reaches the desired distance.
What factors affect the amount of stretch of a spring?
The amount of stretch of a spring is affected by the material and thickness of the spring, the weight and shape of the object being launched, and the force applied to the spring.
How do you measure the amount of stretch of a spring?
The amount of stretch of a spring can be measured by attaching a ruler or tape measure to the spring and measuring the distance between the two ends of the spring when it is at rest and when it is stretched. The difference between the two measurements is the amount of stretch.
What is the formula for calculating the amount of stretch of a spring?
The formula for calculating the amount of stretch of a spring is F = kx, where F is the force applied to the spring, k is the spring constant, and x is the amount of stretch.
How can the amount of stretch of a spring be manipulated for different launch distances?
The amount of stretch of a spring can be manipulated by adjusting the force applied to the spring, changing the material or thickness of the spring, or altering the weight or shape of the object being launched. By manipulating these factors, the spring can be stretched to different lengths, resulting in different launch distances.
