Trying to represent a written geometrical description
In summary, the conversation is discussing Thales and his study of right-angled triangles. The property that the sum of all angles in a triangle is equal to two right angles is mentioned. It is then proposed that Thales examined if this property holds for all right-angled triangles, and it is suggested that by completing the rectangle and drawing the second diagonal, he could see that the diagonals are equal, bisect each other, and the vertical angle of the right-angled triangle is equal to the sum of the base angles. The concept of completing the rectangle is explained as adding a point at (a,b) to the right-angled triangle. The term 'vertical angle' is unclear but it is thought to refer to the angle opposite
CollinsArg
51
I'm reading an old book about Thales (Greek geometry), and I can't understand what the next part means, and how to represent it graphically, could you help me? thanks:
It begin stating that if you divide an equilateral traingle with a perpendicular from a vertex on the opposite side, it'll be divided into two right-angled triangles, equal to each other. Hence the sum of the three angles of each triangle is two right angles. (I can understand this)...then: "If now we suppose that Thales was led to examine whether the property, which he had observed in two distinct kinds of right-angled triangles, held generally for all right-angled triangles, it seems to me that, by completing the rectangle and drawing the second diagonal, he could easily see that the diagonals are equal, that they bisect each other, and that the vertical angle of the right-angled triangle is equal to the sum of the base angles."
(by the property, refers to rule that the sum of all angles of a triangle is igual to two right angles).
So what would it be to "complete the rectangle"?
And, what would it be the vertical angle of the "right-angled triangle"? and the "base angles"?
Just in case, the book is from 1889, so the copyrights are outdated.
Let the right-angled triangle have vertices at points (0,0), (0,b) and (a,0). Then completing the rectangle means adding a point at (a,b). The first diagonal is the hypotenuse of the first triangle and the 'second diagonal' is the line segment from (0,0) to (a,b).
The term 'the vertical angle' is obscure but I think by that he is referring to the angle opposite the hypotenuse (ie the right angle) and 'the two base angles' refers to the two other angles (non-right angles).
Likes CollinsArg
Related to Trying to represent a written geometrical description
1. What is the purpose of representing a written geometrical description?
The purpose of representing a written geometrical description is to provide a visual representation of the described geometric figure. This can help individuals better understand and visualize the figure, as well as aid in solving problems and making accurate measurements.
2. What are some common methods for representing a written geometrical description?
Some common methods for representing a written geometrical description include diagrams, drawings, and 3D models. These methods can vary depending on the complexity of the figure and the intended purpose of the representation.
3. How can representing a written geometrical description aid in problem solving?
Representing a written geometrical description can aid in problem solving by providing a visual representation of the figure, which can help individuals better understand the problem and identify potential solutions. It can also assist in making accurate measurements and calculations.
4. Are there any limitations to representing a written geometrical description?
Yes, there are some limitations to representing a written geometrical description. Some figures may be too complex to accurately represent with a diagram or drawing, and 3D models may not be feasible in all situations. Additionally, the accuracy of the representation may be affected by the skill level of the person creating it.
5. How can technology be used to aid in representing a written geometrical description?
Technology can be used to aid in representing a written geometrical description by providing tools such as computer software and apps that allow for accurate and detailed diagrams and 3D models to be created. These tools can also assist in making measurements and calculations, and may offer features for interactive manipulation of the figure.
  • General Math
