Trying to understand convective heat transfer rate
In summary: If you are heating the air from the bottom, you need to take into account the potential temperature difference between the bottom and the surface: $$dpT=-\frac{h_cA(T_s-T_a)}{V}$$
dmehling
114
I am trying to understand the concept of convective heat transfer. I plugged in some values into the convective heat equation and ended up with q = 40. Now, I don't know what that means. What does that tell me about how long it would take to bring a given volume of air around a hot surface to a given temperature? I need a layman's explanation since my physics background is limited.
Science news on Phys.org
You haven't provided enough detail for us to understand what you are talking about.
Maybe I don't quite understand the point of the equation: q = hc A dT . I plugged in values of hc = 100, A = .01, dT = 40 and the answer was q = 40 w per second. I just want to know what that answer tells me about how much a given volume of air above a hot surface will increase over a given amount of time. Are there other values and factors that I need to know in order to figure this out.
hc is called the heat transfer coefficient. This equation tells you how much heat is passing through the surface into the air above. If the air is pretty well mixed and you are heating it from the surface, you can determine the rate of temperature rise of the air by also knowing the mass and heat capacity of the air: $$MC_p\frac{dT_a}{dt}=h_cA(T_s-T_a)$$
where Ts is the temperature of the surface.
Related to Trying to understand convective heat transfer rate
1. What is convective heat transfer?
Convective heat transfer is the transfer of heat between a solid surface and a fluid in motion. This process occurs when the fluid is in direct contact with the surface, and the heat is transferred through the fluid's movement.
2. How is convective heat transfer rate calculated?
The convective heat transfer rate is calculated using the convective heat transfer coefficient, the temperature difference between the solid surface and the fluid, and the surface area of contact. The formula for calculating convective heat transfer rate is Q = hA(Ts - Tf), where Q is the heat transfer rate, h is the convective heat transfer coefficient, A is the surface area, Ts is the surface temperature, and Tf is the fluid temperature.
3. What factors affect convective heat transfer rate?
The convective heat transfer rate can be affected by several factors, including the fluid's velocity and properties (such as density, viscosity, and thermal conductivity), the surface roughness, the temperature difference between the surface and the fluid, and the geometry of the surface.
4. How does convection differ from conduction and radiation?
Convection is the transfer of heat through the movement of a fluid, while conduction is the transfer of heat through a solid material, and radiation is the transfer of heat through electromagnetic waves. Unlike conduction and radiation, which can occur without any medium, convection requires a fluid to transfer heat.
5. How can convective heat transfer be enhanced?
Convective heat transfer can be enhanced by increasing the fluid's velocity, increasing the surface area of contact, and using materials with high thermal conductivity. Additionally, using fins or other heat transfer devices can increase the convective heat transfer rate by increasing the surface area of contact between the solid surface and the fluid.
  • Thermodynamics
  • Thermodynamics
  • Mechanical Engineering
  • Thermodynamics
