Trying to understand covariant tensor
In summary, the conversation discusses the concepts of contravariant and covariant tensors and their transformations under coordinate changes. It also mentions the use of reciprocal bases and the role of the metric in curved spaces. Ultimately, co- and contravariance are properties of how components of vectors and tensors transform under coordinate transformations.
member 606890
I am taking a course on GR and trying to understand Tensor calculus. I think I understand contravariant tensor (transformation of objects such as a vector from one frame to another) but I am having a hard time with covariant tensors.
I looked into the Wikipedia page (https://en.wikipedia.org/wiki/Covariance_and_contravariance_of_vectors) and came across this figure: (https://upload.wikimedia.org/wikipedia/commons/b/b2/Basis.svg)
The contravariant part makes sense. Vector A is decomposed into components along e1 and e2. However, I do not understand what is meant by "The covariant components are obtained by projecting onto the normal lines to the coordinate hyperplanes." In which direction are these normal lines pointing. I'd appreciate if anyone can help me visualize what is happening.
The ##k##th covariant component of a vector under a basis ##B=\{\vec e_1,...,\vec e_n\}## is its projection on to the 1D normal space of
  • the hyperplane spanned by ##B - \{\vec e_k\}##
In an orthonormal coordinate system (one in which all coordinate vectors are mutually perpendicular and have unit magnitude) that will just be the projection onto the 1D space spanned by ##\vec e_k##. But that won't be the case otherwise.
To visualise, I find it helpful to consider the 2D case where the basis vectors are (1,0) and (1,1). The covariant vectors are perpendicular to those two.
You should look at the concept of a recirocal basis.
If you have one basis that is not orthogonal nor are its vectors unit vectors then you can construct a second basis called a reciprocal basis where each vector of the new basis is orthogonal to a corresponding vector in the original basis and has a magnitude equal to the inverse of the magnitude of original vector.
Then take some reciprocal basis and see how you would have to transform the original basis as well as the reciprocal basis for the two vectors to remain reciprocal to each other. From that you can see how co and contra variant vectors are motivated.
In the most simple case imagine a scalar - say a 4. Its recirocal is 1/4. Now I transform the 4 by multilying by 2. I get 8. But if I use the same transformation to transform the reciprocal I get 1/2 which is not the reciprocal of 8. But if I divide instead of multiply i do get the reciprocal. So there are two transformations required. These end up defining co and contravariance.
For a orthonormal basis the pythagorean theorem yields ds^2=dx^2+dy^2. For a non orthonormal basis that is not true but ds^2= dx*dx' +dy*dy' where dx',dy' is the recirocal basis of dx, dy. So by doing all this they are able to transform two vectors in one system to two in another and still be able to use the vectors to produce scalars.
I'm no expert. I am just a hobbiest. But best I can offer.
One other thin. I am pretty sure that co and contravariance are properties of the transformation. Calling a vector covariant just says how you plan to transform it. If you declare all the contravarient vectors in a basis covarient and then declare all the covarient vectors contravarient you get the same scalars.
While this view works well in Euclidean (or Minkowski) space, it no longer does in a curved space. Generally, without a metric there is no way of taking an inner product and in order to map a vector to a scalar linearly you need an element of the dual vector space. The metric provides a linear map from the tangent vectors to their dual space and therefore an inner product (after noting it has the right properties due to the properties of the metric).
Given a coordinate basis for the tangent vector space - a tsngent vector's components transform contravariantly (because the basis transforms covariantly). Correspondingly, the dual vector components must transform covariantly in order for the contraction with a tangent vector to be a scalar and the dual coordinate basis transforms contravariantly.
This read very strange to me the first time. To clarify, co- and contravariance are properties of how the components transform under coordinate transformations, it is not a property of the coordinate transformation itself.
Let's look at vectors first. By definition contravariant components ##V^{\mu}## of a vector transform as the differentials of the general coordinates ##\mathrm{d} q^{\mu}##, i.e., changing to new coordinates ##\bar{q}^{\mu}## you have
$$\mathrm{d} \bar{q}^{\mu} = \frac{\partial \bar{q}^{\mu}}{\partial q^{\nu}} \mathrm{d} q^{\nu} ={T^{\mu}}_{\nu} \mathrm{d} q^{\nu}.$$
Covavariant components by definition transform like the gradient of a scalar field, i.e., with ##V_{\mu}=\partial_{\mu} \phi## you get
$$\bar{V}_{\mu}=\frac{\partial \phi}{\partial \bar{q}^{\mu}} = \frac{\partial \phi}{\partial q^{\nu}} \frac{\partial q^{\nu}}{\partial \bar{q}^{\mu}}= \frac{\partial q^{\nu}}{\partial \bar{q}^{\mu}} V_{\nu}=:V_{\nu} {U^{\nu}}_{\mu}.$$
Now we have on the one hand
$$\frac{\partial \bar{q}^{\mu}}{\partial \bar{q}^{\nu}}=\delta_{\nu}^{\mu}$$
and on the other hand
$$\frac{\partial \bar{q}^{\mu}}{\partial \bar{q}^{\nu}}=\frac{\partial \bar{q}^{\mu}}{\partial q^{\rho}} \frac{\partial q^{\rho}}{\partial \bar{q}_{\nu}} = {T^{\mu}}_{\rho} {U^{\rho}}_{\nu},$$
and thus
$$ {T^{\mu}}_{\rho} {U^{\rho}}_{\nu} =\delta_{\nu}^{\mu},$$
i.e., ##\hat{U}=\hat{T}^{-1}##, which means that the covariant components transform contragrediently to the contravariant components.
For components of tensors of higher rank, for each index you need to use the rules of transformation as for the co- and contravariant vector components depending on whether you have a lower or upper index.
FAQ: Trying to understand covariant tensor
What is a covariant tensor?
A covariant tensor is a mathematical object that describes how a physical quantity changes as the coordinate system is changed. It is represented by a multi-dimensional array of numbers and has components that transform in a specific way when the coordinate system is changed.
How is a covariant tensor different from a contravariant tensor?
A covariant tensor and a contravariant tensor are similar in that they both describe how a physical quantity changes with a change in coordinates. However, they differ in how their components transform under a change in coordinates. Covariant tensor components transform with the inverse of the coordinate transformation, while contravariant tensor components transform with the coordinate transformation itself.
What are some examples of covariant tensors?
Some examples of covariant tensors include stress tensors, which describe the stress at a point in a material, and the metric tensor, which describes the geometry of space and time in general relativity. Other examples include the electric field tensor, the curvature tensor, and the energy-momentum tensor.
How are covariant tensors used in physics?
Covariant tensors are used extensively in physics, particularly in the fields of relativity and continuum mechanics. They are used to describe the physical laws and equations that govern the behavior of matter and energy. They also play a crucial role in the formulation of theories such as general relativity and the standard model of particle physics.
How can I better understand covariant tensors?
To better understand covariant tensors, it is important to have a strong foundation in linear algebra and calculus. It is also helpful to study the concept of coordinate transformations and how they affect physical quantities. Practice with solving problems and working with different types of tensors can also improve understanding. Additionally, seeking guidance from a teacher or mentor can be beneficial.
