Trying to understand my prof's derivation of Planck's Law
In summary, the professor derived the number volume density using a different method than the PDF proof. He also deviated from Reif's notation and introduced a one-eighth factor offsetting reflections at the boundaries. He arrived at the same result as Reif.
prodo123
Not many people understood his proof in class, and the textbook's proof wasn't very clear so we went by with other derivations online. Then he filled half the midterm with his method, so I'm trying to understand how he did things.
Looking back it seems very similar to the proofs we found online but different in a lot of places.
The goal is to come to the spectral energy density form of
$$u(f)df=\frac{8\pi h f^3}{c^3}\frac{1}{e^\frac{hf}{k_B T}-1}df$$
The closest proof to his method was this: qsp_chapter10-plank.pdf which divides the law into two parts: the number volume density ##\frac{8\pi f^2 df}{c^3}## and the average energy per state ##\frac{hf}{e^\frac{hf}{k_B T}-1}##. I'll refer to this proof as the PDF proof.
The professor divided Planck's Law into three parts instead: number volume density, energy per state ##hf## and state occupation ##\frac{1}{e^\frac{hf}{k_B T}-1}##.
Then he derived the number volume density. The PDF proof gives that since ##n## in all directions is positive we're only concerned with only the positive octant of the reciprocal space, resulting in a factor of 1/8.
The professor does not have that factor. Instead, he starts the proof with ##k=\frac{n\pi}{L}## from the wave in a box scenario, then all of a sudden switches to ##k=\frac{2\pi n}{L}##. The form then looks like:
$$N = 2\big( \frac{L}{2\pi}\big)^3\int_0^{4\pi}\int_0^{k_{max}}k^2 dk d\Omega$$
where ##\frac{L}{2\pi}## is, in his words, the density per dimension and the integral is the volume of the k-space. He specifically put them down separately, raising the power of ##\frac{L}{2\pi}## for each dimension instead of going through (or rather, skipping steps for) the volume integral like the PDF proof.
So from all of this I can't understand:
  • Does state occupation refer to the average state that the photon occupies? How does this state occupation translate from a photon in a box to unbound free space?
  • How did he go from ##k=\frac{n\pi}{L}## to ##k=\frac{2\pi n}{L}## and eliminate the 1/8 factor?
  • He says ##\frac{L}{2\pi}## is density per dimension, and that it's cubed because there's three dimensions. Am I right in interpreting this as the maximum allowed length per state? Or is this a volume of some sort instead of density?
  • He separated physical dimensions ##\frac{L}{2\pi}## from the volume integral. Then he manipulated the integral in another problem as if it referred to physical space instead of reciprocal space. Taken by itself, what does the k-space integral ##\int_0^{4\pi}\int_0^{k_{max}}k^2 dk d\Omega## mean?
I like to use periodic boundary that Reif introduces in his Statistical and Thermal Physics textbook: ## e^{i k_x x }=e^{i k_x(x+L_x)} ## to get ## k_x L_x=n_x (2 \pi) ##, and similarly for ## y ## and ## z ##. ## \\ ## This makes ## \Delta n=(\Delta n_x)(\Delta n_y)(\Delta n_z)=\frac{V \, \Delta^3 k }{(2 \pi)^3}=\frac{V \, \Delta^3 p}{h^3} ##. ## \\ ## Since you are on the subject of the Planck blackbody function, you might find this post of interest, since, in practice, the more important use of the Planck function is to determine the power radiated per unit area from a blackbody surface or from the aperture of a blackbody cavity. https://www.physicsforums.com/threa...-density-of-a-black-body.956343/#post-6063569
Thanks! I took a look at Reif, and he specifically explains the differences between his approach and mine. It's making much more sense.
The prof. and Reif both do not take into account reflections at the boundaries, which restricts allowed values of ##x## to multiples of the whole wavelength and not half-wavelength. In exchange, this also allows for negative ##k##-values which I think corresponds to inverted phase of the wave equation.
On the other hand, by making ##k=\frac{nx}{L}## I'm accounting for reflections and that reflection will invert phase, therefore only allowing positive ##k##-values and introducing the one-eighth factor. As we know both approaches give the identical result.
Reif justified ignoring reflection by saying since ##\lambda## is on the scale of 1Å and ##\lambda \gg L##, the boundary effects are negligible. I don't quite like this justification since ##L## can arbitrarily be made so this condition is not met, but nonetheless it works.
As for the rest of the equation (deviating from Reif's notation),
$$N=d^3 n = dn_x dn_y dn_z = \rho (k) d^3 k$$
where ##\rho(k)## is the density of states (number density per ##k##-state) and ##d^3 k## is the allowed volume element of ##k##-space.
Using the relationship ##k=\frac{n\pi}{L}## we find that the density of states is:
$$\rho(k)=\big( \frac{L}{\pi}\big) ^3 = \frac{V}{\pi^3}$$ for ##k=\frac{n\pi}{L}##, and the volume element is:
$$d^3 k = \frac{1}{8}\int_0^{4\pi} d\Omega k^2 dk$$
The product of these two counts the actual number of states (or particles).
Combining the occupation factor, energy per photon and the polarization factor of 2, Planck's law for spectral energy density can be expressed as:
$$u(k)dk=2\frac{1}{V}\rho(k) \bar{E}\phi d^3 k$$
where ##\bar{E}=\frac{h}{\nu}=\frac{hc}{\lambda}## is the photon energy and ##\phi = \frac{1}{e^{\frac{hf}{k_B T}}-1} = \frac{1}{e^{\frac{hc}{k_B \lambda T}}-1}## is the occupation factor.As for going from spectral energy density to spectral radiance, finding the c/4 factor was a homework problem itself. Your post does it in physical dimensions, but having this division of Planck's law in ##k##-space makes the problem much easier to solve (this bit was what I was referring to when I said prof. was treating reciprocal space like physical space).
Between the spectral energy density and spectral radiance forms of Planck's law:
We know that the number of photons in a cavity of unit volume 1 (spectral energy density) is
$$N_u=\rho (k) d^3 k = \frac{V}{\pi ^3}\frac{1}{8}\int_0^{4\pi} d\Omega k^2 dk \\
N_u=\frac{1}{8\pi^3}k^2 dk\int_0^{2\pi}\int_0^\pi \sin(\theta) d\theta d\phi$$
For spectral radiance, we consider the upper hemisphere of the ##k##-space sphere with the aperture at its apex. I think of this like a projection of outbound rays onto the ray from the center directly through the apex. The cavity can be approximated as a prism or cylinder with volume 1, top area ##A## and length ##c∆t##:
$$N_B=\rho (k)d^3 k = \frac{V}{\pi ^3}\frac{1}{8}\int_0^{4\pi} Ac∆t \cos (\theta) d\Omega k^2 dk \\
N_B=Ac∆t\frac{1}{\pi ^3}\frac{1}{8}k^2 dk\int_0^{2\pi}\int_0^{\frac{\pi}{2}} \cos (\theta) \sin (\theta) d\theta d\phi$$
where the limits for the polar angle ##\theta## is from ##0## to ##\frac{\pi}{2}## because it's the upper hemisphere, and the cosine is the "projection."
Calculating the spectral radiance integral gives ##N_B=\frac{Ac∆t}{4} N_u##, and plugging this into the above form for Planck's law you can find the c/4 factor.
Likes Charles Link
Very good=excellent @prodo123 You did a very thorough job of this topic.:smile::smile:
FAQ: Trying to understand my prof's derivation of Planck's Law
What is Planck's Law?
Planck's Law, also known as the Planck radiation law, is a fundamental law in physics that describes the emission of electromagnetic radiation by a black body. It states that the intensity of radiation emitted by a black body at a certain temperature is proportional to the frequency of the radiation and inversely proportional to the temperature of the black body.
Why is Planck's Law important?
Planck's Law is important because it played a crucial role in the development of quantum mechanics. It provided the first successful explanation for the observed spectrum of black body radiation, which could not be explained by classical physics. It also laid the foundation for the concept of quantization and the understanding of the particle-like behavior of electromagnetic radiation.
What is the significance of understanding my professor's derivation of Planck's Law?
Understanding your professor's derivation of Planck's Law can help you develop a deeper understanding of the underlying principles and mathematics involved in the law. It can also help you apply the law to different scenarios and make connections to other concepts in physics.
What are the main steps in deriving Planck's Law?
The main steps in deriving Planck's Law involve using statistical mechanics and the principles of thermodynamics to determine the distribution of energy among different modes of electromagnetic radiation in a black body. This is then combined with the concept of quantization to arrive at the final equation for Planck's Law.
What are some common misconceptions about Planck's Law?
One common misconception about Planck's Law is that it only applies to black bodies. While it was initially derived for black bodies, it has been shown to apply to other types of objects as well, such as stars and even the cosmic microwave background radiation. Another misconception is that Planck's Law is only applicable to thermal radiation, when in reality it can also be used to describe non-thermal radiation.
