I Trying to understand the inner workings of a solar cell
  • I
  • Thread starter Thread starter Jman99
    Solar cell
The discussion focuses on the mechanics of solar cells, specifically the behavior of electrons in the N-side and how they interact with light-induced electrons. It clarifies that electrons should not be viewed as a "gas" but rather as being in various energy levels, with some being mobile and others not, contributing to voltage generation at the PN junction. The rise in temperature lowers the open-circuit voltage (Voc) because increased thermal energy facilitates recombination of electrons and holes, allowing them to diffuse back against the electric field. There is also confusion regarding recombination losses, with some sources indicating a fundamental loss and others describing it as a percentage of incident power, suggesting a need for clearer differentiation. Overall, the conversation aims to deepen understanding of electron dynamics in solar cells.
Jman99
I understand the basics but one thing sticks out in my mind which I cant make sense of, on the N side there are alot of electrons just sitting there like a gas (presumably with 0 net charge) held back by the internal electric field at the junction, and when light strikes the cell there are many light induced electrons that are swept across to the end of the emitter to flow through the load.
I can't make sense of how these swept electrons travel through that gas of electrons already there, and why in open circuit there is a potential built across the cell if the gas of electrons is there, what makes the collected electrons different than the gas of electrons? I'm just not getting how the gas of electrons and collected electrons mesh together.
Can someone explain exactly how and why the rise in temp lowers Voc? I read the reverse saturation current lowers Voc, but its not really an answer that gives a detailed account step by step.
Finally, for recombination losses, it seems to me there is conflicting info, some sources speak of a fundamental absolutely required loss which i dont know how it actually works, and others simply mention a loss as the electron travels across the junction it can recombine with a slower moving hole, this loss being 10% of the incident power. Are they the same? What is the difference?
thanks
My understanding as a non-expert:
Don't think of the electrons as being in a 'gas', but rather think of them as being in various energy levels, some of which are mobile and some of which aren't. The electron liberated when a photon creates an electron-hole pair is in the conduction band and is able to move quite easily around the material. While this electron exists and before it recombines with a hole, it contributes to an extra negative charge to one side of the PN junction, and many of these electrons combines from lots of light add up to generate a significant voltage, which is what you detect when you measure the open circuit voltage. The holes do the same thing on the other side of the junction, but with the opposite charge.
My limited understanding is that the higher temperature makes it easier for the electrons and holes to recombine by diffusing back against the electric field instead of going through the circuit. Since temperature is generally a measure of how hard particles are vibrating or moving around, a higher temperature gives the electrons and holes more energy to move against the field to recombine.
I can't answer your last question.
Thanks, that all makes sense now about not thinking of them as gas, I never thought of it like.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
