Trying to wrap my brain around entanglement-superposition
  • Thread starter drschools
  • Tags
    Brain
In summary, entangled superposition can be compared to the state of a multiple choice question where there are two or more options for answers before an answer is chosen by the observer/test-taker. The state of the question is in a superposition of possibilities with accompanying probabilities. Once the question is answered, the results take on a differentiated "entangled" state, where the chosen answer determines the state of the other options. This differs from classical probability theory, where the outcome is a single pure state. In QM, pure states can give different outcomes when observed, and measurements in one direction can affect outcomes in another direction. There is no classical analogue for entanglement, making it a unique concept in quantum mechanics.
drschools
Could entangled superposition be something like the state of a mutiple choice question where 1)there are two or more options for answers (...the nature of a multiple choice question:approve:) before an answer is chosen by the observer-test taker and 2) the state of the question once the observer/test-taker answers the question. Before the question is answered the answers are in a kind of superposition - possibilities with accompanying probability. Once answered, the results take on a their differentiated "entangled" state... the one answer "chosen" determines the state of the other options - "not chosen". In binary quantum terms, "chosen" =1 , "not chosen" =0.
In this way the test taker (observer) defines the identity of the answers rather than the designer of the question...i.e. the focus of the answer is on which answer is chosen, not the content of the answer or even if it is right or wrong.
What think thee?
What you are describing is classical probability theory. The possible outcomes are the answers to questions and are called pure states. When the outcome could be a randomly selected pure state that is called a mixed state - that is the questions before an answer is selected. QM is different - the pure states themselves can give different pure states as outcomes if observed (this is called a superposition) - classical probability theory can't do this. If you have a pure state - then that's it - you can't observe it to get another pure state. Every time you observe it you get exactly the same pure state.
Here is an example. Before you throw a dice the outcome is the number 1 to 6 with a probability of 1/6th. That's a mixed state. Throw it and you get 1 to 6. Let's say you get 1. Doesn't matter what you do unless you throw the dice again it will be 1 when you observe it.
Now let's look at QM and see what happens in the famed Stern-Gerlach experiment:
http://en.wikipedia.org/wiki/Stern–Gerlach_experiment
We measure the spin in say the x direction and you get two possible values - called spin up and spin down - suppose it's up. Its in a pure state whose x direction of spin is up. Measure it again and you get the same value - fine. This is exactly the same as the dice situation - sweet. Now measure the the spin in another direction say y and you again get two values - up or down. Say its up so its in a pure state in the y direction of up. Great. But now measure the spin in the x direction - if it was like classical probability theory you should get up. But that's not what happens - you do not get the same value - sometimes its up and sometimes its down. Somehow measuring it in a different direction caused the value in the first direction to change. This is not like your answering question analogy. It would be like you answered question 1 then answered question 2 and somehow that changed the answer to question 1. Pure states do not remain 'fixed' like in classical probability theory.
QM also has mixed states - which are randomly selected pure states - but it has the added feature observations can change pure states into other pure states.
Check out:
http://arxiv.org/pdf/quant-ph/0101012v4.pdf
http://arxiv.org/pdf/0911.0695v1.pdf
Thanks
Bill
I appreciate the feedback and references Bill. I'm hungry to learn more, so you gave me more to chew on.
Thanks
Dave
Just to underline Bill's point a bit: there is no classical analogue of entanglement. I know it's helpful when learning someone to try to draw analogies between what you're studying and what you already know, but such analogies are very precarious in quantum mechanics. Some of the key ideas in QM, like entanglement, aren't like anything else you're already familiar with. So, the answer to, "Is entanglement like X?" (where X is some everyday thing) is always going to be no.
FAQ: Trying to wrap my brain around entanglement-superposition
What is entanglement-superposition?
Entanglement-superposition is a phenomenon in quantum mechanics where two or more particles become connected in such a way that the quantum state of one particle is dependent on the state of the other(s), even when separated by large distances. This means that the particles share a single quantum state, and any change in one particle will immediately affect the other(s), regardless of how far apart they are.
How does entanglement-superposition occur?
Entanglement-superposition occurs when two or more particles interact in a way that creates a single quantum state. This can happen through various processes, such as collisions, interactions with other particles, or being created together in the same quantum system.
What is the significance of entanglement-superposition?
Entanglement-superposition has significant implications for our understanding of the fundamental laws of physics. It challenges our classical understanding of cause and effect, as entangled particles can seemingly influence each other instantaneously, regardless of distance. It also has potential practical applications in quantum computing and communication, as entangled particles can be used to encode and transmit information in a secure and efficient way.
Can entanglement-superposition be observed in everyday life?
No, entanglement-superposition is a phenomenon that occurs at the quantum level and is not observable in our everyday lives. It requires highly controlled experimental conditions and specialized equipment to be observed and studied.
How does entanglement-superposition relate to the concept of superposition?
Entanglement-superposition is a specific type of superposition, where particles exist in multiple states simultaneously. In entanglement-superposition, the particles share a single quantum state, whereas in regular superposition, a single particle can exist in multiple states at the same time. Entanglement-superposition is a more complex and interconnected form of superposition, and it plays a crucial role in many quantum phenomena and technologies.
