- 893
- 483
- TL;DR Summary
- Are there sneaky tricks for compensating for measurement noise in a PID servo?
Hi all! Forgive the sloppiness of this post, I'm on the road.
Suppose you have a servo loop to stabilize parameter X. The issue is, when you measure X, you introduce some measurement error (let's say its white noise for the sake of argument). The noise causes a potential problem: since the error signal now contains some noise signal that is uncorrelated with X, the servo will end up adding this noise to X. I feel like this is a situation which must have been studied extensively. Is there a standard limit on servo performance in the presence of this kind of measurement noise? Are there fancy tricks to get past this limit?
For a simple example, X might be laser power as measured on a photodiode. The servo controller reads the photodiode voltage and adjusts some laser settings to correct the optical power. Suppose the photodiode voltage is DC + white noise (the white noise being shot noise from the diode, thus uncorrelated with the optical power).
My specific case is stabilizing residual amplitude modulation (aka RAM) for an electro-optic modulator (EOM). I can get into the nuts and bolts if you like, just let me know in a reply. Alternatively, here's a paper: https://arxiv.org/abs/1710.08575
