Tuning circuit in mobile handset system
In summary, the question is why a mobile phone handset has a tuning circuit for reception but not for transmission. The reason for this is that during transmission, the handset is dealing with one specific carrier frequency, but during reception, the aerial picks up multiple signals, so a tuning circuit is needed to select the desired signal. However, in some cases, a PLL may also be used in transmission depending on the modulation scheme used.
Lama Al Najjar
Studying about Communication Skills specifically about mobile handset and how do they transmit and receive signals etc. I came across this question which states
"Why does a mobile phone handset have a tuning circuit for reception stage but not for transmission?
The attempt at a solution
I was thinking during the transmission stage you will be dealing with one particular type of carrier frequency, however when its time for receiving the signal since the aerial produces plenty of signals each time then a tuning circuit is needed to pick up the signal required. I wonder if what I stated is correct , please correct me if I am not.
Welcome to the PF.
I think your answer is reasonable, but it would be good to know more about the context of the question. Depending on the modulation scheme used, a PLL may be used in transmission (for example in a frequency synthesizer circuit) as well as in reception.
Likes Lama Al Najjar
Related to Tuning circuit in mobile handset system
1. What is a tuning circuit in a mobile handset system?
A tuning circuit in a mobile handset system is a component that is responsible for filtering and adjusting the frequency of signals within the handset. It ensures that the signals being transmitted and received are at the correct frequency for optimal performance and minimal interference.
2. How does a tuning circuit work in a mobile handset system?
A tuning circuit typically consists of a combination of inductors, capacitors, and resistors that are arranged in a specific configuration to create a resonant frequency. This frequency can be adjusted by changing the values of these components, allowing for precise tuning of the signal.
3. Why is a tuning circuit important in a mobile handset system?
A tuning circuit is crucial in a mobile handset system because it helps to eliminate unwanted signals and interference, ensuring clear and reliable communication. It also allows for the efficient use of the limited frequency spectrum available for mobile communication.
4. Can a tuning circuit be adjusted or modified?
Yes, a tuning circuit can be adjusted or modified by changing the values of its components. This can be done during the manufacturing process or through software updates in the handset. However, it is important to note that any modifications should be done carefully to avoid causing damage to the circuit or affecting the performance of the handset.
5. What are some common issues that can arise with a tuning circuit in a mobile handset system?
Some common issues that can arise with a tuning circuit in a mobile handset system include poor signal quality, dropped calls, and interference from other devices. These can be caused by faulty components, improper tuning, or external factors such as network congestion. Regular maintenance and proper handling can help prevent these issues.
  • Electrical Engineering
  • Science Fiction and Fantasy Media
  • Computing and Technology
