I Tunneling with Gaussian Wave Packet
Tertius
TL;DR Summary
I have a simulation built of an initial wave packet approaching a barrier and tunneling.
The goal is to have accurate 1D numerical results for tunneling probabilities through an arbitrary barrier without relying on analytic approximations such as WKB. If there is a more ideal approach to this, I am happy to change tactics. Time independent, for example, but I am not sure how to set up the boundaries at the edges so it doesn't become a bound system.
Most of the resources i've found detail way to solve for bound systems (oscillators, potential wells, etc), but I haven't found one that produces tunneling probabilities from a numerical method.
My initial simulation is a Gaussian wavepacket approaching a barrier, but I am finding that the numerical results are of course dependent on the initial location of the wavepacket. This is expected because the time evolution spreads out the wavepacket as it approaches the barrier.
I am attaching a snapshot of the simulation (both real and imaginary parts of ##\psi## are shown). I am computing the tunneling probability as the integrated probability after the barrier divided by the integrated probability before the barrier (computed at each time step, and taking the maximum).
I am concerned this approach is dependent on initial position. Is there a better general approach?
previously consulted resources:
https://arxiv.org/html/2403.13857v1#S3 https://www.reed.edu/physics/faculty/wheeler/documents/Quantum Mechanics/Miscellaneous Essays/Gaussian Wavepackets.pdf
You should try a higher central momentum for the wave packet then. You want to be in a regime where the spreading of the wave packet is negligible (compared to ##d\braket{x}/dt##) over the entire simulation.
In the conditions I mentioned above, you will get a splitting of the wave packet into separated reflected and transmitted parts, from which you can calculate the transmission probability, which will be independent of time once the interaction with the barrier is over (assuming that the wave packet never reaches the end of the grid). The maximum might not correspond to the long-time (converged) result.
Also, for square barriers you can get exact transmission probabilities for a plane wave (see, e.g., Sakurai's Modern Quantum Mechanics). The numerical result can of course differ as you are using a wave packet, but it is possible to make the wave packet narrow enough in momentum such that the two results are practically indistinguishable.
That makes sense. And then, from what i've found in literature, it is common to have the spreading parameter ##\sigma = \frac{h}{2 \lambda}##. That should, in combination with the momentum being high enough, give physically real and consistent results, I would hope.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
