Turing machine - polynomial time expression
In summary: The key idea is that the running time of an algorithm is O(n^k) for some constant k, which means that the running time grows no faster than some polynomial function of the input size n.
xeon123
90
In the Turing Machine, the machine accepts a word if the computation terminates in the accepting state. The language accepted by the machine, L(M), has associated an alphabet Δ and is defined by
L(M) = {w [itex]\in[/itex] [itex]\Delta[/itex]}
This means that the machine understands the word w if w belongs to the language.
We denote by Tm(w) the number of steps in the computation of M on the input w. If the computation never halts, then Tm(w)=infinity.
Also, we denote the worst case run time of M as
Tm(n) = max{Tm(w)}
which means the biggest words in the dictionary (I suppose).
But, we say that M runs in polynomial time if there exists k such that for all n, T(n)[itex]\leq[/itex] n^k + k.
I don't understand what n^k+k means. Can anyone explain me the last expression?
Thanks,
Mathematics news on Phys.org
Tm(n) = max{Tm(w)}
Thanks,
Your definition for polynomial time seems to be a little off. It's usually defined as T(n) ≤ nk, without the additional k term that you showed.
If you do a search for "polynomial time" this is one of the links that you'll see: http://www.wordiq.com/definition/Polynomial_time.
Related to Turing machine - polynomial time expression
1. What is a Turing machine?
A Turing machine is a theoretical model of a computer that can simulate any algorithm or computation. It consists of a tape, a head that can read and write symbols on the tape, and a set of rules that determine the machine's behavior.
2. What is the significance of polynomial time expression in a Turing machine?
A polynomial time expression in a Turing machine refers to the amount of time it takes for the machine to solve a problem. A polynomial time expression means that the problem can be solved in a reasonable amount of time, making it an efficient algorithm.
3. How does a Turing machine calculate polynomial time expressions?
A Turing machine calculates polynomial time expressions by using a specific set of rules and symbols to manipulate the tape. These rules are designed to solve a specific problem in a finite number of steps, making the calculation efficient.
4. Can a Turing machine solve any problem in polynomial time?
No, a Turing machine is not capable of solving every problem in polynomial time. There are some problems, such as the traveling salesman problem, that are considered NP-hard and require exponential time to solve.
5. How does the concept of polynomial time relate to the complexity of a problem?
A polynomial time expression in a Turing machine indicates that the problem can be solved efficiently and has a lower complexity. A problem with a higher complexity, such as exponential time, would require much more time and resources to solve.
