B Turn one vector into another vector
  • B
  • Thread starter Thread starter askmathquestions
    Vector
askmathquestions
This might seem like a novice question, but let's suppose we have a vector ##x## and we want to turn it into vector ##y##. Well, what square matrix multiplied on ##x## accomplishes this?
As an example, let's work with a ##2 \times2## case:
##x = \begin{bmatrix} x_1 \\ x_2 \end{bmatrix}## and ##y = \begin{bmatrix} y_1 \\ y_2 \end{bmatrix}##, then what transform ##T = \begin{bmatrix} t_{1,1} & t_{1,2} \\ t_{2,1} & t_{2,2} \end{bmatrix}## makes the equation ##Tx = y## true?
Well,
##\begin{bmatrix} y_1 \\ y_2 \end{bmatrix} = \begin{bmatrix} t_{11} & t_{12} \\ t_{21} & t_{22} \end{bmatrix} \begin{bmatrix} x_1 \\ x_2 \end{bmatrix}##
So
##y_1 = t_{11} x_1 + t_{12} x_2##
##y_2 = t_{21} x_2 + t_{22} x_2##
You have two equations in four unknowns so you can set some conditions on T if you like. But that's the proceedure.
-Dan
This is where I got stuck, because how do we solve for the ##t_{i,j}## components? Or, what conventional restrictions are there?
You have two equations in four unknowns. So you can solve for two of the in terms of the remaining two unknowns. So you can set two more conditions.
There are a number of restrictions you can impose. You can set T to be unitary, det(T) = 1, Tr(T) = 0, you can make T symmetric or antisymmetric, skew-symmetric, etc. Or you could just simply say, "I want ##t_{11} = \pi## and ##t_{21} = 0##." As long as you don't run into a contradiction you can do just about anything you like. Of course you would want to tailor your conditions to whatever problem you are working with.
-Dan
Likes Hall and malawi_glenn
One approach would be to express the vectors in polar form:
$$\vec v_1 = (x_1, x_2) = (r\cos \theta, r\sin \theta)$$$$\vec v_2 = (y_1, y_2) = (R\cos \phi, R\sin \phi)$$Then the rotation matrix for the angle ##\phi - \theta##, followed by the identity matrix multiplied by ##\frac R r## would do the trick.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
