san_1420
- 10
Is it true that Newton proved that it is possible to turn a ball inside out without dissecting it using calculus.
That explains it .ThanksGalileo said:I found this site:
http://www.xs4all.nl/~alife/sphere1.htm
It was not until the 1970s that
the (blind !) mathematician Bernard Morin came up with a visualization,
based on work by Arnold Shapiro.
It is possible to turn a ball inside out without dissecting it by using a mathematical concept called the "hairy ball theorem." This theorem states that it is impossible to comb the hair on a ball flat without creating a cowlick. By applying this concept, one can create a continuous motion that flips the ball inside out without any cuts or tears.
Theoretically, yes, this concept can be applied to any type of ball. However, the size and flexibility of the ball may affect the difficulty level of the task.
The time it takes to turn a ball inside out using the hairy ball theorem can vary depending on the skill and practice of the person attempting it. It can take anywhere from a few minutes to several hours.
This concept has been applied in various fields such as robotics, computer graphics, and materials science. In robotics, it is used to design flexible joints that can bend and rotate in different directions. In computer graphics, it is used to create realistic animations of objects turning inside out. In materials science, it has been used to design materials with specific properties and structures.
If done carefully and with the proper technique, there should be no risk of damaging the ball while turning it inside out. However, it is important to use a ball that is flexible enough to withstand the turning motion without breaking or tearing.
