Twice of supersymmetric transformation = translation
In summary: But I would rather say that the defect in the "parallelogram law" is responsible for making a translation (along with the extra $i$ in front).In summary, Supersymmetry is a generalization of spacetime symmetry and can be seen as a "square root" of translation. The anticommutator of two supersymmetric transformations results in a translation in spacetime due to the addition of Grassmann directions in superspace. This is analogous to a round trip in the Grassmann direction, which does not bring you back to the starting point but instead results in a shift in the usual spacetime direction. This defect in the "parallelogram law" is also responsible for creating a translation.
wphysics
29
Hello, I have one conceptual question. I have been working on Supersymmetry.
Now, I understand that twice of supersymmetric transformation is equivalent to translation mathematically(naively).
However, I don't quite understand why this should be the case conceptually. Supersymmetric transformation is that boson to fermion and fermion to boson, meaning that it changes spin by 1/2. How can twice of it be equivalent to just translation?
I just want a conceptual answer, so it does not need to be super consistent.
Thank you in advance.
Twice a supersymmetric transformation = supersymmetric transformation. I don't know why you say that you have just translation. Otherwise you wouldn't be able to form a group.
What is equivalent to a translation is the commutator of two supersymmetric transformations.
In Super Poincare algebra, we know that the anti commutator of two weyl spinors is proportional to translation. This is the equivalence that I am talking.
Thanks
So you are asking why [itex] \{ Q_a , \bar{Q}_\dot{b} \} = 2 \sigma^\mu_{a\dot{b}} P_\mu [/itex] ?
Yes! I am wondering why it is the case conceptually.
Hmmm.. haven't thought about it...
But looking at it, the anticommutator will give you something like [itex](1/2 , 0) \times (0 ,1/2)[/itex] (the times symbol looks weird here but I hope you understand what I wanted to point out), so it seems natural for me to give you a normal Lorentz repr (and not an irrep). So the [itex]\sigma^\mu [/itex] and the momentum.
Yes. That explanation is the most common one. Let me put it in this way. For spin 0 particle, supersymmetric transformation transforms it to spin 1/2 particle. If we do again, it should be back to spin 0 and effectively, its effect is translation.
I cannot draw this picture in my head physically.
That's the reason why you can look at supersymmetry as a generalization of spacetime symmetry. And when you write a SUSY element in exponential form, you don't only add the spinor generators Q,Q* but also the momentum. I think it's intrinsic to it for closure reasons. Otherwise you can try to have a look at the Coleman-Mandula theorem.
You can regard supertransformations Q as translations in the fermionic direction, and P as translations in spacetime. Both are as such translations in superspace.
@wphysics
The best way to think about your query, in my opinion is look at the converse of the situation i.e. a susy transformation is DEFINED as a "square root" of a translation. This is exactly analogous to the way we define/picture spinors as "square root" of a vector following Dirac (who as the folklore has it arrived at the Dirac spinor equation by taking a "square root" of Klein-Gordon operator).
There is no simple way to motivate why a square of susy transformation is translation, but as some other members have pointed out, perhaps we need to augment our spacetime with Grassmann directions in addition to usual spacetime i.e. picture a larger spacetime (superspace) . And then the anticommutator of two susy transformation can be seen as a round trip in the Grassman direction, and this round trip does not bring you at the starting point, instead you get a shift along the usual spacetime direction i.e. a translation. This is bit like moving around in a helix every 360 degree doesn't return you to your original position but you arrive a point veritcally shifted over the starting point along the axis.
Well it is still not enough, because you don't make two fermions... it's a QQ* combination (left/right-handed fermions)...
You are semi-correct :). You compose two supersymmetry and then undo it by acting in reverse order (for bosons this AB-BA, for fermionic operations, its AB+BA). This set of two operations and then the reveres constitutes the departure from "parallelogram law" with the departure/defect being a translation operation. Two fermions of opposite handedness indeed can be turned into a vector using Pauli matrices ($\sigma^{\mu}$).
Related to Twice of supersymmetric transformation = translation
1. What is supersymmetric transformation?
Supersymmetric transformation is a mathematical concept in physics that describes a relationship between particles with different spin properties. It is a symmetry that relates fermions (particles with half-integer spin) to bosons (particles with integer spin).
2. How is supersymmetric transformation related to translation?
Supersymmetric transformation is related to translation because it is a type of symmetry that preserves the spatial location of a particle. In other words, when a particle undergoes a supersymmetric transformation, its position in space remains the same.
3. What does it mean for the twice of supersymmetric transformation to equal translation?
This statement means that when a particle undergoes two consecutive supersymmetric transformations, it results in a translation. In other words, two supersymmetric transformations can be combined to produce a translation in space.
4. How does supersymmetric transformation impact the study of particle physics?
Supersymmetric transformation has been a topic of interest in particle physics because it helps to unify different theories and models of particles and their interactions. It also provides a framework for studying the relationship between different types of particles.
5. Are there any practical applications of understanding "twice of supersymmetric transformation = translation"?
Yes, there are practical applications of this concept in fields such as quantum mechanics and string theory. Understanding the relationship between supersymmetric transformation and translation can help us better understand the behavior of particles and their interactions, which can have implications for technologies such as quantum computing.
  • Beyond the Standard Models
11K
  • Nuclear Engineering
