MHB Twin Prime Conjecture : A Brief History of the Present
The Twin Prime Conjecture has a rich history, beginning with V. Brun's 1915 result that established the convergence of the sum of twin primes' reciprocals. Subsequent advancements included Erdős's 1940 findings on prime gaps and the 2004-2005 work by Goldston-Pintz-Yildirim, which suggested infinitely many prime pairs with small gaps. Yitang Zhang's 2013 breakthrough demonstrated infinitely many prime pairs with gaps smaller than $7 \times 10^7$, later refined by Terence Tao and others to even tighter bounds. Recent developments have seen further reductions in the bounds, with Sutherland achieving significant improvements in tuple bounds. The ongoing research continues to push the boundaries of understanding in this area of number theory.
mathbalarka
I don't know if such thread has been created, all I can find out is one mentioning Zhang's initial bound of $7 \times 10^7$. This has been greatly improved by now so I thought it is worthwhile to post it here as well as the resources which I somehow collected from here and there.
History; a glance through the past
(1915) V. Brun showed that the sum of reciprocals of twin primes converges[1], quite the opposite of primes. This was a major result in twin prime history. The rough implication of the result was that there are not too many twin primes there up to some $N$. Indeed, a consequence of the result was that there are $k N/\log^2 N$ twin primes for some constant $k > 0$. The method uses some basic sieve theoretic (combinatorial) methods which at present is named upon him, i.e., Brun sieve.
(1940) Erdos showed[11] that $\frac{p_{n+1} - p_n}{\log p_n} \leq k$ for some constant $k \leq 1$ and it was improved greatly by Goldston-Pintz-Yildirim by showing that $k \approx 0.08578$.
(2004-2005) Goldston-Pintz-Yildirim showed that the constant can be assumed to be arbitrarily small, i.e., $\lim \inf \frac{p_{n+1} - p_n}{\log p_n} = 0$ and further that there are infinitely many prime pairs with gap 16, assuming Elliot-Halberstam conjecture.[2],[3]
I might be missing something, but these are the most major improvements I can recall.
Present; to be written in mathematical history
(2013) Y. Zhang showed that that there are infinitely many prime pairs with some gap smaller than $7 \times 10^7$.[4] This was the smallest unconditional ever obtained. In a similar fashion, although much explicit, Tao proves a more general result[9] tightening the bound to 57554086.
After some explicit reduction on the bound by Tao and Morrison, Tao announced a proposal of polymath project[5],[6]. The best unconditional result, upto July 5, was 5414 which was greatly improved by Maynard's works[7].
The current best known trustworthy result is 300 by Clark & Jarvis[8], which is a consequence of Nielson's upper bound of 59[10].
References
  1. http://www.math.uga.edu/~lyall/Analysis/brunsieve.pdf
  2. D.A. Goldston, Y. Motohashi, J. Pintz, & C.Y. Yıldırım, Small Gaps between Primes Exist
  3. D. A. Goldston, S.W. Graham, J. Pintz, & C. Y. Yildirim, Small gaps between primes or almost primes
  4. Yitang Zhang, Bounded gaps between primes
  5. Terence Tao, Polymath proposal : bounded gaps between primes
  6. Polymath project, Bounded gaps between primes
  7. James Maynard, Small gaps between primes
  8. David A. Clark, Norman C, Jarvis, Dense admissible sequences
  9. Terence Tao, The prime tuples conjecture, sieve theory, and the work of ... and Zhang
  10. Pace Nielsen, Comment : Polymath8b, III: Numerical optimization of the ... search for new sieves
  11. Jerri Li, Erdos and twin prime conjecture
Mathematics news on Phys.org
I wanted to keep everyone informed about this. Current improvements :
  • (Dec 20) Nielson made it to $55$, without Deligne. That implies the bound of $272$, which is the tightest possible.
  • (Dec 22) Sutherland pushes the 3-tuple bound to $395122$ unconditionally.
  • (Dec 23) Sutherland gives $k_0 = 530000$ for 6-tuples, unconditionally and without Deligne's theorem. A major improvement.
  • (Dec 24) Sutherland again. 5-tuple assuming Elliot Halberstam is now at $474320$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
