Two balls are thrown vertically upward, one with an initial speed twic
In summary: The ball with higher velocity has shorter time..o...i get it loll using vf^2 = vi^2 + 2ad, a is constant for both casesbut if u use the other equation, t varies so the ans is not correct !
cmkc109
103
Two balls are thrown vertically upward, one with an initial speed twice that of the other. The ball with the greater initial speed will reach a height
- twice that of the other
- 4 times that of the other
dy = vt + 1/2 at^2
[if i use this equation, i will get twice of the other]
vf^2 = v1^2 + 2ad
-v1^2 = 2ad
[if i use the equation, i will get 4 times of the other]
I get both 2 times and 4 times..
cmkc109 said:
dy = v + 1/2 at^2
This is incorrect. You might want to show here how you get this result.
i made a typo
it is dy = vi t + 1/2 at^2
this is one of the kinematic equation
It seems to me that projectile motion is difficult for many because every second post is about it but that's ok.
cmkc109 said:
i made a typo
It is indeed a valid equation, but your result is still incorrect.
Galileo created the whole science called "physics" by considering projectile motion, so it should not be surprising that it is a hot topic in teaching of this science. That's why it is so frequent here, not because it is difficult for many. Well, some problems may be surprisingly difficult.
Yes, but in general projectile motion problems are easy because if you understand the concept you can solve the problem using only a couple of kinematic equations.
why is it incorrect? can u explain why?
The correct result is 4 times. I cannot explain why you are not getting the correct result using this method, you have not shown your working.
i did not do any work. it's simply because dy - at^2 = vi t
so there is no square sign
What about t? Is it the same in both cases?
no.. the ball with higher velocity has shorter time..o...i get it loll
using vf^2 = vi^2 + 2ad , a is constant for both cases
thhxx
It might be helpful for you to compute the time it takes to reach highest point in both cases.
FAQ: Two balls are thrown vertically upward, one with an initial speed twic
What is the initial speed of the two balls?
The initial speed of the two balls is twice the speed of the first ball thrown.
How high will the balls reach?
The height reached by the balls will depend on the initial speed and acceleration due to gravity. The first ball will reach a higher height as it has a greater initial speed.
What is the acceleration of the balls?
The acceleration of the balls is constant and is equal to the acceleration due to gravity, which is 9.8 meters per second squared.
What happens when the balls reach their maximum height?
At maximum height, the balls will momentarily stop and then start falling back towards the ground due to the force of gravity.
How can you calculate the time it takes for the balls to reach the ground?
You can use the equation t = √(2h/g), where t is the time, h is the height reached, and g is the acceleration due to gravity. This will give you the time it takes for the balls to reach the ground from their maximum height.
