Two blocks on a frictionless surface; find the force
In summary, two blocks, A and B, with masses of 2.0kg and 4.0kg respectively, are pushed on a frictionless surface by a force of 30 N to the right. The magnitude of the force that Block B exerts on Block A is 20 N, which is determined by treating the objects as individuals and applying Newton's second and third laws.
Peter Halsall
Two blocks, A and B , are being pushed on a frictionless surface by a froce of 30 N to the right, .Block A has a mass of 2.0kg, Block B, being pushed by Block A is 4.0kg. Calculate the magnitude of the force that block B exerts on Block A.
f=ma
If The total force pushing the blocks as a system is 30 N, then if you treat the objects as individuals 20 N of the force is provided by Block B and 10 N by Block A. So 20 N is the magnitude of the force that Block B exerts on Block A
Is fine, but can you express it more formally in terms of ##F = ma## for the ensemble and for each of the blocks ?
I'm sorry, I don't understand what your asking, do you want me to prove it using Newton's 2nd law?
Yes. F = ma for the total, a is the same for A and B so with F = ma for B the force needed to accelerate B is the 20 N you found. And from Newton 3 B exerts a reaction force of the same magnitude on A.
Related to Two blocks on a frictionless surface; find the force
1. What is the definition of "frictionless surface"?
A frictionless surface is a hypothetical surface with no resistance to motion. In reality, all surfaces have some level of friction, but a frictionless surface is often used in physics problems to simplify calculations.
2. How do you calculate the force needed to move two blocks on a frictionless surface?
To calculate the force needed to move two blocks on a frictionless surface, you will need to use Newton's second law of motion, which states that force equals mass multiplied by acceleration. In this case, the mass of the two blocks can be added together and the acceleration can be determined based on the applied force and the combined mass of the blocks.
3. What is the relationship between the force and the mass of the two blocks on a frictionless surface?
The relationship between force and mass on a frictionless surface is directly proportional. This means that as the mass of the two blocks increases, the force needed to move them will also increase.
4. Can the force needed to move two blocks on a frictionless surface ever be zero?
Yes, the force needed to move two blocks on a frictionless surface can be zero if the blocks are already in motion and no additional force is needed to maintain their velocity. However, if the blocks are at rest, some force will be needed to overcome their inertia and start them moving.
5. How do other factors, such as gravity or air resistance, affect the force needed to move two blocks on a frictionless surface?
In a frictionless system, other external factors like gravity or air resistance do not affect the force needed to move the blocks. However, in real-world scenarios, these factors can affect the motion of objects and may need to be taken into account when calculating the force needed to move the blocks.
