Two cars travel at the same speed of 105 km/h
In summary, two cars traveling at the same speed of 105 km/h have different external horizontal forces exerted on them due to the difference in their motors. The sleek sports car with a motor delivering 35 kW of power experiences less air resistance than the other car with a motor needing to produce 65 kW of power. According to Newton's third law of motion, each car exerts forces in opposite directions. The magnitude of the forward force exerted by each car on the air can be calculated. The energy transferred by the car engines comes from the fuel they consume.
physics_kills
Two cars travel at the same speed of 105 km/h. One of the cars, a sleek sports car, has a motor that delivers only 35 kW of power at this speed. The other car's motor needs to produce 65 kW to move the car at this speed. Forces exerted from air resistance cause the difference.
A) For each car, list the external horizontal forces exerted on it, and give the cause of each force. Compare their magnitudes.
B) According to Newton's third law of motion, each car exerts forces. What are the directions of these forces?
C) Calculate the magnitude of the forward force exerted by each car on the air.
D) The car engines did work. Where did the energy they transferred come from?
I really have no clue where to begin when solving this problem, and I'd love some help if anyone knows how to do this! Thank you sooo much!
Hi there,
Probably the best tip one can give you is to make a drawing of the situation. It does not have to be pretty (we are not artist, but doing physics), just explaning the situation. Once you have you two cars drawn, then imagine what are the forces acting upon them. The rest should come easily.
Cheers
A) The external horizontal forces exerted on each car are the driving force from the engine and the air resistance force. The cause of the driving force is the motor of the car, while the cause of the air resistance force is the air particles colliding with the car as it moves. The magnitude of the air resistance force will be greater for the car with the weaker motor, as it needs to exert more power to maintain the same speed.
B) According to Newton's third law, for every action, there is an equal and opposite reaction. Therefore, each car will exert a force on the air in the opposite direction of its motion.
C) The magnitude of the forward force exerted by each car on the air can be calculated using the formula F = ma, where F is the force, m is the mass of the air being displaced, and a is the acceleration of the air. Since both cars are traveling at the same speed, their accelerations are the same. However, the car with the weaker motor will need to displace more air to maintain the same speed, so it will exert a greater force on the air.
D) The energy transferred by the car engines comes from the fuel they burn. The fuel contains chemical energy, which is converted into kinetic energy (energy of motion) by the car's engine. This kinetic energy is then transferred to the wheels, which move the car forward. Some of this energy is also used to overcome the air resistance force and maintain the car's speed.
Related to Two cars travel at the same speed of 105 km/h
1. How do you calculate the distance between the two cars?
The distance between the two cars can be calculated by multiplying their speed (105 km/h) by the time they have been traveling for. For example, if both cars have been traveling for 2 hours, the distance between them would be 210 kilometers (105 km/h x 2 hours = 210 km).
2. Can the speed of the cars change during their travel?
It is possible for the speed of the cars to change during their travel. However, for this question, we are assuming that both cars are maintaining a constant speed of 105 km/h throughout their journey.
3. How long will it take for the cars to reach a distance of 500 kilometers?
To calculate the time it will take for the cars to reach a distance of 500 kilometers, we can divide the distance by the speed. In this case, it would take approximately 4.76 hours (500 km / 105 km/h = 4.76 hours).
4. What is the average velocity of the two cars?
The average velocity of the two cars is the total distance traveled divided by the total time taken. In this case, if both cars have been traveling for 4 hours, their average velocity would be 105 km/h (210 km + 210 km / 4 hours = 105 km/h).
5. How far apart will the cars be after 3 hours?
After 3 hours, both cars would have traveled a distance of 315 kilometers (105 km/h x 3 hours = 315 km). Therefore, the distance between them will be 315 kilometers.
15K
