Two concentric conducting spherical shells and resistor in between
  • #36
zenterix said:
I think I have the capability to think like both.
I think you could also argue that disregarding such nuance would be the approach of some engineers, and that such details would be called academic by them.
In fact, I think that unless we go into the physics nuance this whole problem is useless unless you are practicing integration.
I still don't see the point of this problem really.
Yes ok you might have both an engineering and scientific mind. In my opinion it is more engineering than scientific on how the current circulates but ok i might be wrong here.
Its a good problem if you ask me, unusual resistor configuration and current density distribution. You should be intrigued by unusual problems.
  • #37
I just want to make sure…..this thread is not so much about how to solve the problem but rather about the premise of the problem. Correct?
Edit: I did a google search for “spherical resistors” to see if they were commercially available and apparently they are not. The only thing that showed up was problems like the one in the OP. So maybe it is purely theoretical.
  • #38
Slight problem not exactly with the premise but the statement of the problem. For me at least it wasn't so obvious that the current inside this resistor will reach a steady state but if one has the necessary insight can see it and this steady state doesn't need to be explicitly stated in the problem like an assumption.
Yes maybe that engineering detail on how to complete the circulation of current is a big problem. The theoretical interest I find in this is that it is a resistor structure such that the current is spatially constant within the resistor but the current density again inside this resistor isn't spatially constant.
Likes PhDeezNutz
  • #39
zenterix said:
Is this resistor purely theoretical?
Not necessarily. I can imagine how it could be a reasonable approximation to something real, perhaps in the context of a living cell.
You would have been happier, presumably, with concentric cylinders. The same concentric shell analysis applies.
  • #40
The OP was about solving the problem. I did not foresee any of the ensuing doubts about the solution you provided because I did not think that we could have current flowing radially through the spherical setup. I then asked if that was realistic and then we got to this topic of if this type of scenario is possible in real life.
  • #41
haruspex said:
I don't understand your difficulty. A shell radius r, thickness dr, with radial current, is a resistor length dr and area ##4\pi r^2##. Plug that into the formula.
I guess you're right it is that simple.
Likes PhDeezNutz
  • #42
I don’t think you’re wrong for asking these questions. You’re right I was a bit on “auto-pilot” when answering the question. Maybe that’s a bad habit I developed to merely get through school.
Likes zenterix
  • #43
Delta2 said:
I insist you must edit the first sentence of your post to "Just because the current density is steady, does not mean is the same everywhere"
Insist ?
Really, did you say Insist ? !!!!
  • Haha
Likes Delta2
  • #44
Delta2 said:
I would define steady state here as the state that in which the total current through a conceptual spherical shell of any radius r, is independent of r.
No, the latter can be true purely by symmetry even before steady state is reached.
We are asked for the resistance. How are you going to define that while not in steady state?
Charge flow follows the diffusion equation, and it is in the nature of that equation to tend to a steady state, though in theory it might never get there.
  • #45
Hmm you are mostly right here, but I think there is not complete symmetry , it depends on the way we apply the source voltage to the inner and outer surfaces, if it is applied by thin wires that touch the surfaces (inner and outer) at specific points, there is not complete symmetry IMO.
Anyway you know how much I hate symmetry arguments :eek: though I have to admit your are mostly right here.
Yes again you are mostly right here maybe something 95% right. I don't know I just feel the problem statement is kind of incomplete without stating the steady state assumption.
