Two conducting spheres a distance d away with charges +q and -q
The interaction between two conducting spheres with charges +q and -q cannot be simplified to point charges at their centers due to non-uniform charge distribution. As the spheres approach each other, their surface charges redistribute, leading to higher charge density in the areas closest together. This results in a stronger attractive force than predicted by the point charge approximation, as the effective distance between the interacting charges is less than the distance d. In contrast, if the spheres were insulators, the charge distribution would remain uniform, allowing for the point charge treatment. Thus, the presence of conducting materials significantly alters the force dynamics between the spheres.
Jaccobtw
Two conducting spheres are a distance d away with charges +q and -q. Is the attractive force equal to, greater than, less than ##k_e q^2/d^2##, or zero
Coloumb's Law
you can treat the center of two conducting sphere's like two point charges. Therefore it should be equal to ##k_e q^2/d^2##, but the answer is greater than ##k_e q^2/d^2##. Can someone explain how? Thank you
The surce charge density in both spheres isn't uniform. Thus, we can't say the charge distribution can be replaced by a points charges at the spheres ' centers. Opposite charges tend to attract (they're closer) and this results in a larger force.
Likes Jaccobtw and Delta2
Yes I think @Gordianus is right. I 'll try to explain a bit in more detail what he means:
Because the spheres are conductors, when we bring them close together their surface charges interact and more charge of each sphere is moved toward the areas of the spheres that are close together. So their surface charge density isn't uniform anymore and you can't treat the sphere as point charges. Because there are these accumulated charges positive on one sphere and negative on the other which are distanced apart much less than ##d##, the attractive force is bigger.
If the spheres were insulators then their charges wouldn't interact, the surface charge density on each sphere would remain uniform and you could treat the spheres as point charges.
