Two Conducting Spheres Problem - Applying
In summary, the problem involves two identical conducting spheres that initially attract each other with an electrostatic force of 0.108 N at a center-to-center separation of 50.0 cm. When the spheres are connected by a thin conducting wire and then removed, they repel each other with a force of 0.0360 N. The net charge on both spheres is positive, and using Coulomb's law, it can be determined that the negative charge on one sphere is equal to the positive charge on the other. The sum of the two charges must be greater than or equal to zero, and using the positive root of the equation, the values for the negative and positive charges can be solved for.
PFStudent
170
9. Two identical conducting spheres, fixed in place attract each other with an electrostatic forces of 0.108 N when their center-to-center separation is 50.0 cm. The spheres are then connected by a thin conducting wire. When the wire is removed, the spheres repel each other with an electrostatic forces of 0.0360 N. Of the initial charges on the spheres, with a positive net charge, what was
(a) the negative charge on one of the, and
(b) the positive charge on the other?
[tex]
\vec{F}_{12} = \frac{kq_{1}q_{2}}{r^2}\hat{r_{21}}
[/tex]
I know I can use Coulomb's law to solve this problem, however I want to just make sure I first understand the vector form of it.
So, the law
[tex]
[/tex]
basically says that q1 and q2 are treated as positive where the: negative sign for attraction or positive sign for repulsion; comes from the radial hat vector right?
Ok, so for example in this problem, we have two charges q1 and q2:
http://img162.imageshack.us/img162/1843/91rg6.png
Ok, so using the vector form of coulomb's law I treat q1 and q2 as positive charges and the negative sign for attraction should come from the radial vector...but how?
And since this is a radial vector the direction of [itex]\hat{r_{21}}[/itex] is that: the distance beginning at q2 to q1 or beginning at q1 to q2?
PFStudent said:
So, the law
[tex]
[/tex]
No. The sign comes from the product of the two charges, which can be positive or negative. If the charges are opposite, you'll have a negative sign--which means the direction is opposite to radial unit vector and thus towards the other charge (in other words, attractive).
Treat the charges as they are: one positive, one negative.
It stands for a unit vector pointing from charge 2 towards charge 1. Thus if the charges had the same sign, the direction of the force would be repulsive.
Hey,
Doc Al thanks for the information.
Ok so proceeding to the solution.
Coulomb's Law:
[tex]
\vec{F}_{12} = \frac{kq_{1}q_{2}}{r^2}\hat{r}_{12}
[/tex]
Can be rewritten with the scalar component [itex]F_{12}[/itex]
[tex]
\vec{F}_{12} = F_{12}\hat{r}_{21}
[/tex]
Also it is known that q1 and q2 are unlike-sign to account for the initial attraction.
Therefore, letting [itex]F_{12} = 0.108 N \equiv +[/itex].
and [itex]F'_{12} = 0.0360 N \equiv +[/itex]. We have:
[tex]
-{F}_{12} = \frac{k_{e}q_{1}q_{2}}{r^2}
[/tex]
[tex]
{F'}_{12} = \frac{k_{e}{q'}_{1}{q'}_{2}}{r^2}
[/tex]
Where [itex]{q'}_{1}[/itex] and [itex]{q'}_{2}[/itex] represent the charges after the wire is removed. And so due to Conservation of Charge.
[tex]
{q'}_{1} = {q'}_{2} = \left(\frac{{q}_{1} + {q}_{2}}{2}\right)
[/tex]
And therefore,
[tex]
{F'}_{12} = \frac{k_{e}(q_{1}+q_{2})^2}{4{r^2}}
[/tex]
In solving the above for [itex](q_{1}+q_{2})[/itex], the problem that arises is whether to choose the positive or negative root to solve for q1 and q2. And justifying that choice.
[tex]
q_{1}+q_{2} = \pm\sqrt{\frac{4{r^2}{{F'}_{12}}}{{k}_{e}}}
[/tex]
(Note: Either root will lead to the same values, however signs will be reversed and because part (a) explicitly asks for the negative charge, then only either one of the two possible roots may be used to solve for the unknowns, q1 and q2.)
Any ideas on this?
Thanks!
-PFStudent
Recall that the net charge on both spheres is positive. What does that tell you about [itex](q_{1}+q_{2})[/itex]?
Hey,
Thanks Doc Al for the help, and because the original problem specifies that the net charge on both spheres is positive, this mathematically means that the sum of the two charges is greater than or equal to zero.
Or in other words,
[tex]
(q_{1}+q_{2}) \geq 0
[/tex]
Which implies that only the positive root of,
[tex]
[/tex]
[tex]
\therefore
[/tex]
[tex]
q_{1}+q_{2} = +\sqrt{\frac{4{r^2}{{F'}_{12}}}{{k}_{e}}}
[/tex]
will lead to the correct values for the (a) negative charge and (b) positive charge.
Man, I learned a lot from this problem, :)
Thanks for the help Doc Al!
-PFStudent
P.S. Sorry for the late response.
Excellent. I am delighted that you stuck with it. Good work.
Related to Two Conducting Spheres Problem - Applying
1. What is the Two Conducting Spheres Problem?
The Two Conducting Spheres Problem is a classic problem in electrostatics that involves two charged conducting spheres in close proximity. The goal of the problem is to determine the electric potential and electric field at various points between and around the spheres.
2. What are the main assumptions made in the Two Conducting Spheres Problem?
The main assumptions made in the problem are that the spheres are perfect conductors, there are no external electric fields, and the charge on each sphere is evenly distributed on the surface. These assumptions simplify the problem and allow for a more straightforward solution.
3. How is the Two Conducting Spheres Problem solved?
The problem can be solved using the method of images, which involves creating a virtual image of the spheres with opposite charges and using the principle of superposition to find the electric potential and field. Alternatively, the problem can also be solved using the method of separation of variables, which involves solving Laplace's equation for the potential between the spheres.
4. What are some real-world applications of the Two Conducting Spheres Problem?
The Two Conducting Spheres Problem has applications in various fields, including electrical engineering, electrostatics, and physics. It can be used to understand the behavior of parallel plate capacitors, electric circuits, and charged particle interactions.
5. What are some limitations of the Two Conducting Spheres Problem?
The Two Conducting Spheres Problem makes several simplifying assumptions that may not accurately reflect real-world scenarios. For example, the assumption of perfect conductors may not hold in some cases, and external electric fields may exist. Additionally, the problem does not take into account the effects of induction and polarization, which may be significant in certain situations.
11K
