Two dimensional motion problem (kicking a soccer ball into the goal)
The discussion focuses on solving a two-dimensional motion problem involving kicking a soccer ball into a goal. The user initially applies the formulas for the x and y components of motion but realizes discrepancies in their calculations, particularly regarding the angle of projection. A correction is suggested for the x component equation, emphasizing the need to consider the total flight time and ascent time. Additionally, the importance of using the correct gravitational constant is highlighted, as it affects the calculations. The conversation concludes with a reminder to utilize the formulas for range and total time of flight to solve the problem accurately.
Ineedhelpwithphysics
Carli Lloyd scored half-field goal (53 m) vs. Japan with a beautiful projectile motion. It looks from the video that the ball was inthe air for 2.0 seconds. What was the angle of the ball when it left her foot?
VoX = vcos(theta)
VoY = vsin(theta)
Vf(y) = Vo(y) + a(y)t
Delta y = VoY + 1/2a(y)t^2
I did this too fast idk if I'm wrong
So for the x component
use the formula d = rt / delta x = v*t
26 = vcos(theta)
y component
use the displacement formula
19.6 = vsin(theta)
tan^-1(19.6/26) = 36.5 degrees
the answer key says 20.2 degrees idk whats wrong
I did wrong calculations please ignore this
I get the angle 20.67 with ##g=10m/s^2##.
Your first equation is almost correct, it should be $$\frac{53}{2}=v_0\cos\theta$$
But no clue how did you infer the 2nd equation.
Hint: if the total flight time is 2.0 sec what is the total ascent time, ##t_A## ,that is the time the ball rises from the initial point to its highest point, and how ##v_{0y}=v_0\sin\theta## relates to ##t_A##?
Now I see that your second equation is also almost..... correct up to a factor of 2 e hehe and with ##g=9.8m/s^2##
What is the formula the for range ##R## of a projectile and its total time of flight ##T##? Those two are the ones you need to answer the question @Ineedhelpwithphysics
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
