Two dimensional Square well and parity
These are the four smallest energies that can be obtained as the sum of two squares.Now, as for the parity, remember that odd*odd=even, odd*even=odd and even*even=even. So, if m and n are both odd, the product is even, and the energy is even. On the other hand, if one is even and one is odd, the product is odd and the energy is odd. And if they are both even, the product is even again. So, the parity of the sum of two squares depends only on whether the two numbers are odd or even, regardless of their actual values. That is why E(1,1) is one state, E(1,2) and
Firben
145
A particle is placed in the potential (a 2 dimensional square well)
V(x) = (0 for -a/2 <= x =< a/2 and -a/2 <= y =<a/2, infinity for x>a/2, x<-a/2 and y>a/2, y<-a/2)
The hamiltonian commutes with the parity operator P, Pψ(x,y) = ψ(-x,-y) = λψ(x,y), where the eigenvalue λ can take two possible values +(-)1 Write down the eigenstates corresponding to the four lowest energies in such a way that they are also eigenfunctions of the parity operator P. What is the parity of these states?
I calculated the eigenfunctions and i got:
ψ(x) = √(2/a)*sin(nπx/a), n=2,4,6,.. (odd)
ψ(x) = √(2/a)*cos(nπx/a), n=1,3,5 (even)
E(n,m) = E(n) + E(m)
E(n,m) = (π^2*(h-bar)^2)/(2*M*a^2)*(n^2+m^2)
In the solution manual it says (n^2+m^2) = 2,5,8,10
How did they come up with those numbers ?
the odd is 2,4,6 and the even is 1,3,5, so how can (n^2+m^2) = 2,5,8,10 ?
and this also in the solution manual:
E(1,1) = one state (n^2+m^2) = 2, odd*odd = even
E(1,2)=E(2,1) = two states (n^2+m^2) = 5, odd*even = odd
E(2,2) = one state (n^2+m^2) = 8, even*even = even
E(1,3) = E(3,1) = two states (n^2+m^2)=10, odd*odd = even
What do they mean with E(1,1), E(1,2) etc ?. How can E(1,1) be one state and E(2,2) be two states ? Where did they get odd*even from ?
The eigenfunctions you have written down in your relevant equations are those in 1D but we have a 2D system, so an eigenfunction of the full problem has the form
[itex]\psi_{mn}(x,y)=\psi_{m}(x)\psi_{n}(y)[/itex]
where m and n label the solutions you have given.
Now, the energy of such a solution is just the sum of the energies in 1D and they are labeled by the two integers m and n. The energies are quadratic in n and m, so the full energy depends on the sum of the squares [itex]n^2+m^2[/itex]. The smallest sums you can get this way are 1+1=2, 1+4=5, 4+4=8 and 1+9=10.
FAQ: Two dimensional Square well and parity
1. What is a two dimensional square well?
A two dimensional square well is a potential energy function that describes the interaction between a particle and a two dimensional region. It is typically represented as a square with a finite depth and width, and the potential energy within the well is constant.
2. How is the potential energy of a two dimensional square well related to the particle's energy?
The potential energy of a particle in a two dimensional square well is directly related to the particle's energy. When the particle's energy is lower than the potential energy within the well, it is confined to the well. However, when the particle's energy is higher than the potential energy, it can escape from the well.
3. What is the role of parity in a two dimensional square well?
Parity refers to the symmetry of a physical system under a specific transformation. In a two dimensional square well, the potential energy function is symmetric with respect to parity. This means that the potential energy remains the same when the position of the particle is reflected across the origin.
4. How does the energy spectrum of a two dimensional square well differ from a one dimensional square well?
In a one dimensional square well, the energy spectrum is discrete and can only take on certain values. However, in a two dimensional square well, the energy spectrum is continuous and can take on any value within a certain range. This is due to the additional degree of freedom in the two dimensional system.
5. What is the significance of the boundary conditions in a two dimensional square well?
Boundary conditions play a crucial role in determining the energy states and wave functions of a particle in a two dimensional square well. The boundary conditions dictate the behavior of the wave function at the edges of the well, and can affect the energy spectrum and the probability of the particle being found in certain regions of the well.
