Two Electric Dipoles-Net Charge of Zero
In summary, the conversation discusses the net force between two electric dipoles in empty space, with a net charge of zero on each dipole. Coulomb's Law is used to show that this net force is zero, but the internal charges of the dipoles result in a slight separation and alignment of the dipoles. The conversation also mentions explicitly writing out expressions for the force on each charge using Coulomb's Law to further analyze the situation.
cactusblanket
Hi there,
Can someone help out with this problem?
Thank you.:redface:
Consider two electric dipoles in empty space. The net charge of each dipole is zero, so does an electric force exist between them?
F=kq1q2/r2
If I solve for F with Coulomb's equation it yields zero, but that just seems too simple.
Can you show your work? It is correct to treat each dipole to be formed from two point charges of opposite polarity. It can be shown that, for particular orientations of the two dipoles, Newton's third law is not obeyed in the strong form.
With regard to showing my work, I used Coulomb's Law and inserted a net charge of zero which yields: Force = zero.
Would it be correct to state that the net force between electric dipoles is zero, but since they are polarized, (the positive and negative charges redistributing themselves to a certain degree, slightly more positive on one end, slightly more negative on the other.) the slightly separated internal charges create their own field resulting in the dipoles aligning themselves positive to negative.
Cheers
Place two dipoles on the x-y plane. Label the four charges by 1,2,3 and 4, where 1 and 2 constitute one dipole and 3 and 4 the other. Charge 1 experiences a force from 2,3 and 4. Charge 2 experiences a force from 1,3 and 4. Similarly for 3 and 4. Write explicit expressions for the force on each charge using Coulomb's law.
The resulting analysis will show that, as you pointed out, the force on, say 1 from 2 is internal and does not contribute to the net force on the dipole.
Thank you!
FAQ: Two Electric Dipoles-Net Charge of Zero
What is a two electric dipoles-net charge of zero?
A two electric dipoles-net charge of zero refers to a system of two equal and opposite electric dipoles that cancel each other out, resulting in a net charge of zero. A dipole is a separation of positive and negative charges within an object.
How is the net charge of zero achieved in a two electric dipoles system?
The net charge of zero is achieved in a two electric dipoles system by positioning the dipoles in such a way that their electric fields cancel each other out. This can be achieved by placing the dipoles at equal distances from each other and ensuring that they have opposite orientations.
What are the applications of two electric dipoles with a net charge of zero?
Two electric dipoles with a net charge of zero have various applications in physics and engineering. They are commonly used in electrical circuits to achieve balanced potentials and in antenna designs to produce circularly polarized radiation.
Can two electric dipoles with a net charge of zero produce a non-zero electric field?
Yes, two electric dipoles with a net charge of zero can still produce a non-zero electric field. This is because the electric field is a vector quantity and the electric fields of the two dipoles can cancel each other out in some directions but add up in others.
What is the difference between a two electric dipoles system and a single electric dipole?
The main difference between a two electric dipoles system and a single electric dipole is that the former has a net charge of zero while the latter has a non-zero net charge. This results in different electric field patterns and behaviors. Additionally, two electric dipoles can cancel each other out, while a single electric dipole cannot.
