Two electric field problems - pick one or both
In summary: So you can use the kinematic equation to solve for q. In summary, for the first problem, you need to use the Coulomb force as the equivalent of the Newton gravitational force and solve for the speed of the electron using kinematic equations. For the second problem, you need to use the Coulomb force to find the acceleration and then use kinematic equations to solve for the magnitude of charge q.
absolutezer0es
Here are two problems, both of which I'm not really sure where to start. The simpler (?) one first:
A 1.10-mm-diameter glass sphere has a charge of +1.10 nC. What speed does an electron need to orbit the sphere 1.80mm above the surface?
I thought of using v = (2*pi*r)/T because it is circular motion, but I can only derive "r" (I got r = 0.00235m, though I'm not sure if this is right. I know the sphere acts as a point charge and measured the 1.8mm and the radius of the sphere.). I don't feel like the electric field equations would get me anywhere.
Question 2 (and more complex):
The ink drops have a mass m = 1.00×10−11kg each and leave the nozzle and travel horizontally toward the paper at velocity v = 22.0m/s . The drops pass through a charging unit that gives each drop a positive charge q by causing it to lose some electrons. The drops then pass between parallel deflecting plates of length D0 = 1.65cm, where there is a uniform vertical electric field with magnitude E = 8.10×104N/C .
If a drop is to be deflected a distance d = 0.250mm by the time it reaches the end of the deflection plate, what magnitude of charge q must be given to the drop? Assume that the density of the ink drop is 1000kg/m3 , and ignore the effects of gravity.
This one ... not a clue where to begin. I've got my electric field formulas ready to go. I'd appreciate any nudges you guys can give on either problem.
For the first, you can think of the Coulomb force as the equivalent of the Newton gravitational force for charges (this is not quite right, accelerated charges would radiate, but I think that's all what the problem is about, just neglect radiation).
In the second, you must use some kinematics (same thing here about radiation, just neglect it), with the acceleration given by the Coulomb force for the charge. You see that the positive charge will be accelerated when it enters the region with the uniform electric field, right? then just use ##x_f=x_0+v_it+\frac{1}{2}at^2##, where a is the acceleration given by the Coulomb force.
For the first, I've got nothing. Generically, I developed:
Q = (16*pi*epsilon-naught*m*r^3)/(eT^2)
I don't think this is it. I solved for T then and got 7.35x10^-8, but I don't think I'm on the right track.
For the second, I found all sorts of kinematic values - can't connect them to q, though. I found values for a, t, and theta, but can't connect them to find charge. Don't think my theta is right though either, which was 2.53x10^-6.
Well, the charge q appears in the Coulomb force, which gives you the acceleration, right?
For the first problem, you are correct in using the equation v = (2*pi*r)/T. However, you need to consider the force of the electric field on the electron as well. The centripetal force required for the electron to orbit the sphere is equal to the electric force between the electron and the sphere. So you can set up the equation:
mv^2/r = kQq/r^2
Where m is the mass of the electron, v is the speed, r is the distance between the electron and the sphere, k is the Coulomb's constant, Q is the charge of the sphere, and q is the charge of the electron. You can solve for v using this equation.
For the second problem, you can use the same equation to calculate the electric force on the ink drop, and then use the equation F = ma to calculate the acceleration of the drop. Since the drop is moving horizontally, the electric force will cause it to move in a curved path, and the distance d is the vertical component of this path. From there, you can calculate the magnitude of the charge q using the equation:
q = mgd/E
Where m is the mass of the ink drop, g is the acceleration due to gravity (which we can ignore in this case), d is the distance, and E is the electric field strength.
I hope this helps! If you need more clarification or additional assistance, don't hesitate to ask. Good luck with your problems!
Related to Two electric field problems - pick one or both
1. What are the two electric field problems?
The two electric field problems refer to the concept of electric fields in physics. These problems involve calculating the strength and direction of the electric field at a given point due to a point charge or a group of charges.
2. How do you calculate the electric field of a point charge?
To calculate the electric field of a point charge, you can use the formula E = kQ/r^2, where E is the electric field strength, k is the Coulomb's constant, Q is the magnitude of the point charge, and r is the distance from the point charge to the point where the field is being measured.
3. What factors affect the strength of an electric field?
The strength of an electric field is affected by the magnitude of the charge, the distance from the charge, and the medium in which the charge is located. The electric field is stronger for larger charges, closer distances, and in materials with lower dielectric constants.
4. How do you calculate the electric field of a group of charges?
To calculate the electric field of a group of charges, you can use the principle of superposition. This means that you can calculate the electric field of each individual charge and then add them vectorially to find the total electric field at a given point.
5. What are some real-life applications of electric field problems?
Electric field problems have many practical applications, such as in designing electronic circuits, understanding the behavior of lightning, and studying the interactions between charged particles in particle accelerators. They are also important in fields such as electromagnetism, engineering, and telecommunications.
