Two equations "combined" don't give the desired result
  • Thread starter Thread starter nomadreid
    Special relativity
The discussion addresses a potential typo in the Lorentz transformation equation, specifically noting that x' should not be in the denominator of equation (5.6.7). A participant expresses confusion over how to combine this corrected equation with another to derive a relation between time variables t and t'. Initial attempts at substitution and algebraic manipulation resulted in complications, leading to uncertainty about the derivation process. After receiving clarification, the participant realizes a minor mistake in their calculations and successfully resolves the issue. The interaction highlights the importance of careful algebraic manipulation in understanding complex physics equations.
nomadreid
From only (A) x'=g(x-vt) and (B) x^2-(ct)^2=x'^2-(ct')^2 derive
(C) t'=g(t-(vx/c^2)),
g= gamma = 1/sqrt(1-(v/c)^2) and the equations in the Statement
In https://phys.libretexts.org/Bookshe...__Relativity/5.06:_The_Lorentz_Transformation
First, the equation (5.6.7) apparently has a typo: the x' should not be in the denominator, as one can see by comparing it with the equation just above it from which it was derived. The corrected equation is Equation (A) in the Statement (standard Lorentz transformation).
Then two equations down (unnumbered), the author states the equation (B) in the Statement,
"We combine this with Equation 5.6.7 that relates x and x' to obtain the relation between t and t′:"
and then states the equation (C) in the statement.
How he means to "combine" them is what I don't successfully get. I tried substitution of x' from (A) into (B), and got a mess; I then tried solving (B) for x', and substituting this solution into (A), and got the same mess, that is,
(A) into (B)
which doesn't simplify to (C). Either: (a) my algebraic manipulation is wrong; (b) the author is including some other equation in the derivation.
Any indications where this is going wrong would be greatly appreciated. (Yes, there are other ways to derive the relation (C), but I am interested in this author's derivation.)
Yes it does (up to the sign of the square root).
Thanks, Orodruin. OK, I will try again, now with the assurance that I just made some minor mistake made in simplifying. That fully answers my question! Super!
update: found the error. It all comes out. Thanks again, Orodruin
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
