Two Equations for Average Velocity?
  • Thread starter Thread starter Spooky123
    Average velocity
Average velocity is defined as the change in position (displacement) divided by the change in time, while average speed is the total distance divided by total time. The discussion clarifies that average velocity is a vector quantity, contrasting it with average speed, which is a scalar. To calculate average velocity correctly, one must determine the total displacement by adding individual displacements and the total time by summing the time taken for each segment of the journey. The approach outlined for finding average velocity is correct, emphasizing the distinction between average velocity and average speed, particularly in cases of non-linear motion. Understanding these concepts is crucial for accurate calculations in physics.
Spooky123
You walk in the direction of the unit vector <1,0, 0> a distance of214 m at a constant speed of 3.6 m/s, then turn and walk in the direction of the unit vector <1, 0, 1>/ root 2 for a distance of 16 m at a constant speed of 3 m/s. What was your average velocity?
Vavg = delta r / delta t
I know that average velocity is the change in position over the change in time. But im getting conflicting views from other sources saying thats its the total distance divided by the total time. For this question we would first find the respective vectors by multiplying the distance with the given unit vectors. Then according to the average velocity formula we would find the difference between both vectors (change in position). To find the respective times, we would use the distance divided by the speed given for each. Using the final formula for avg velocity should give us the answer.
R1 = <21,0,0>m
R2 = <11.31,0,11.31>m
Delta R = R2 - R1
= <-9.69,0,11.31>
t1 = d1/v1 = 21/3.6 = 5.833
t2 = d2/v2 = 16/3 = 5.33
Delta t = t2 - t1 = -0.5
Thus, Average velocity = Delta R / Delta T?
Is this the right way to go about it?
Hi @Spooky123. Welcome to PF.
Ok but it might be clearer to say that average velocity is the total displacement divided by the total time taken.
Average velocity is a vector. The total distance covered (a scalar) divided by the total time taken (also a scalar) gives the average speed, not the average velocity.
R1 = <21,0,0>m
Delta R = R2 - R1
= <-9.69,0,11.31>
No. <21, 0, 0>m is not a position vector, It's a displacement (change in position). Similarly for <11.31, 0 , 11.31>m.
To get the total displacment you must add the individual displacements. E.g. if you move 5m in the +x-direction and then 10m in the +x-direction, your total displacement is 15m in the x direction.
No. If the first part of the journey takes time t₁ and the second part takes time t₂, the total time for the whole journey is ???
If ΔR were the correctly calculated total displacement and ΔT were the correctly calculated total time, that formula would be correct.
Likes MatinSAR and Spooky123
Average velocity = Change in position vector divided by time interval.
Average speed = Total distance traveled (odometer reading from start to finish) divided by time needed to travel that distance.
Two different ideas. If it takes you time ##T## to go around a complete circle of radius ##R##, then
Average velocity = Zero.
Average speed = ##\dfrac{2\pi R}{T}.##
Your approach for finding the average velocity is correct. Note that for motion at constant velocity in a straight line, the average velocity has magnitude equal to the average speed. You rely on this idea to find the correct times required to travel in each direction separately and then add the times to find the total time over which the displacement takes place. Note that when an object moves at constant speed along a curved line, the average speed and the average velocity have different magnitudes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
