Two Horizontal Forces Working On an Object
In summary, based on the given information, there are only two horizontal forces acting on a 3.0 kg body on a frictionless floor: 9.0 N due east and 9.4 N at 68° north of west. Using the equation F=ma, the net force in the x-direction (horizontal) is 5.47869 N, and the net force in the y-direction (vertical) is 2.905 N. From this, the magnitude of the body's acceleration is calculated as 3.4 m/s^2. However, the correct answer is given as 3.34 m/s^2, indicating a discrepancy in the calculations.
richard karn
Only two horizontal forces act on a 3.0 kg body that can move over a frictionless floor. One force is 9.0 N, acting due east, and the other is 9.4 N, acting 68° north of west. What is the magnitude of the body's acceleration?
F=ma
Fnet= 9 - 9.4cos(68) = 5.47869
F=ma
5.47869= 3.0 * a
a=1.826232
The right answer is 3.34 though.
Your answer agrees with mine.
I disagree. Fnetx is that, yes, but you forgot about Fnety.
(I'm calling East-West the x direction, and North-South the y-direction).
thanks. i was thinking as the other force as pushing into the ground so it wouldn't be accelerating in that direction but then
but 9.4sin(68)/3=2.905
and sqrt(2.905^2+1.8^2) = 3.4
Hmm, the object with a 3 kg mass has a weight force of about 30 N acting down. How can it have acceleration in the y direction?? Then again the problem notes there are only 2 horizontal forces acting, but one of them is neither horizontal nor vertical, it is at an angle. Strangely worded problem. Maybe the object and floor are in a zero g or apparent zero g field? That still doesn't explain the 'horiziotal' force acting 68 degrees north of west.
FAQ: Two Horizontal Forces Working On an Object
What is the equation for calculating the net horizontal force on an object?
The equation for calculating the net horizontal force on an object is Fnet = F1 + F2, where Fnet is the net horizontal force, F1 is the first horizontal force acting on the object, and F2 is the second horizontal force acting on the object.
How do you determine the direction of the net horizontal force on an object?
The direction of the net horizontal force on an object can be determined by adding the individual horizontal forces acting on the object. If the sum is positive, the net force is in the same direction as the forces. If the sum is negative, the net force is in the opposite direction.
What is the difference between balanced and unbalanced horizontal forces?
Balanced horizontal forces refer to a situation where the net horizontal force on an object is zero, meaning the forces are equal in magnitude and opposite in direction. Unbalanced horizontal forces refer to a situation where the net horizontal force on an object is not zero, meaning there is a resulting force that will cause the object to accelerate in the direction of the net force.
Can horizontal forces change the velocity of an object?
Yes, horizontal forces can change the velocity of an object. If the net horizontal force on an object is not zero, the object will experience acceleration in the direction of the net force. This acceleration will cause a change in the object's velocity.
How do you calculate the acceleration of an object with two horizontal forces acting on it?
The acceleration of an object with two horizontal forces acting on it can be calculated using the equation a = Fnet/m, where a is the acceleration, Fnet is the net horizontal force, and m is the mass of the object. First, calculate the net horizontal force by adding the individual forces. Then, divide the net force by the mass of the object to determine the acceleration.
